Injector Removal??? PLEASE HELP!!!
Old 10-21-2003, 09:31 PM
GreyBoy's Avatar
Hey, Im installing my new DD2s, and I gotto the part where I remove the stock injectors. But I cant seem to get them out...Please help
98 24v
Old 10-21-2003, 10:12 PM
StakeMan's Avatar
Re:Injector Removal??? PLEASE HELP!!!
Take the injector lines loose. Pull the injector tube out a little. Then with the injector hold downs removed. Use an intake bolt and screw into the top of the injector. With the injector tube pulled out, you should be able to use a small pry bar and pop the injector out.
Old 10-21-2003, 11:16 PM
thumper 549's Avatar
like stakeman said ,,look at the top of the inj. it's a metric bolt hole ,,thread one in part wat and pry up
Old 10-22-2003, 02:21 PM
hellotbone's Avatar
I think he has a 12 V not a 24v and I don't think the DD2's are gonna work my friend.
Old 10-22-2003, 02:30 PM
drecu's Avatar
Jamie why do you think he has a 12V?
DRecu!
Old 10-22-2003, 06:12 PM
GreyBoy's Avatar
Well actually, I do have a 12v. I discovered that while I was trying to install my 24v injectors Thanks for the help guys.
Thanks,
Sam
Cummins Freak
12-14-2007 12:22 AM
M1AM14SPUR
10-13-2007 07:20 PM
SuperiorRam
03-15-2007 03:10 AM
mkrenn
02-24-2006 01:12 PM
kawi600
01-26-2006 10:19 AM
Quick Reply: Injector Removal??? PLEASE HELP!!!
