Injector port size
Old Sep 16, 2007 | 12:16 AM
12vsvo's Avatar
Injector port size
I’m looking to get a compression tester. Does anyone know the size of injector ports for the 5.9? Are they 24mm? Is that the same as older 80’s Mercedes? Is there a difference in between the 93 and 94’s? All I know is my 93 takes a 17mm wrench on the injector line nuts, and my 94 takes a 19mm. I wonder if this one will work from Harbor Freight?
View more US General items
DIESEL ENGINE COMPRESSION TESTER
Designed to check compression on most domestic and foreign diesel engines.
· Quick-connect adapter
· Reads pressure from 0 to 1000 PSI
· 2-9/16" diameter gauge
· Thumb button air release
Comes with adapters for GM, Ford, Lincoln, Isuzu, Mercedes Benz, Kubota, Toyota, Volkswagen, Peugeot
ITEM 93644-0VGA
$24.99
Old Sep 16, 2007 | 10:56 AM
infidel's Avatar
Don't know if it works but this one for sure does
http://www.harborfreight.com/cpi/cta...emnumber=93039
DSmith1178
May 30, 2007 07:38 AM
QWKRTNU
Sep 26, 2006 10:22 PM
ckennedy
Nov 10, 2004 01:03 PM
