Injector lines
Injector lines
I wanted to check the little blue fasteners that hold the lines from vibration.Anyone know what size wrench,also what size wrench to change the lines,thx.
10 mm and 19 mm. get a # 4 injector line and carry with you. cummins part # is 4988808 it will be $22 to $28 it is made of different metal and the isolator has a torx screw
I walked into a Cummins commercial shop in Odessa, TX a few month ago and asked for the #4 fuel line. One of the counter guys was telling me he needed the engine serial number to make sure I got the right one. The other counter guy walked away and came back with the 4988808 box in his hand. I think it was $24.50 out the door.
Went and got the 10mm and 19mm flat wrenches.The 19mm is correct,could not see where the 10mm fit??On my 06 the fastener took a 8mm socket,no torx head,a flat wrench is needed as no room to use a ratchet.THX
