Inductive Tachometer?
Old Sep 6, 2003 | 02:26 PM
FORDNOMORE's Avatar
Hello everyone out there,
My question is, can a inductive tachometer be wired to work on my '91 D250?
Thanks in advance
Old Sep 6, 2003 | 03:18 PM
Monty's Avatar
Re:Inductive Tachometer?
Yes you can. I believe some tachs come with the alternator hookup. Another alternative is the http://www.tinytach.com which takes readings off of the injector pulses. Later models of the first gen trucks 91.5 - 93 I believe, came with a crank sensor with an existing connector you could wire into.
Old Sep 6, 2003 | 05:09 PM
FORDNOMORE's Avatar
Ok, so if my truck has the crank sensor wires where would I find them? I'm still learning my engine. Thanx
Old Sep 7, 2003 | 01:10 AM
DodgeCowboy's Avatar
DTR's Cow Boss
I know that in the 93s there was a four pin wire under the driver side of the dash my guess thats were i would start to look
Old Sep 8, 2003 | 01:11 PM
Paul S.'s Avatar
Do you know the colors of the wires? I need to get in there and might just as well kill two birds with one stone...
Thanks,
Paul
Old Sep 8, 2003 | 01:36 PM
Monty's Avatar
Paul, here are the wire colors that match to the Isspro tach.
https://www.dieseltruckresource.com/...p;onlynewfaq=1
Old Sep 8, 2003 | 09:29 PM
hippie's Avatar
on my 93 D350 has the hook up taped to the wire bundel going to the fuse panel, I pulled my fuse cover off and it was real easy to get to. It is more of a flat type of connector and the spades are in line. There are four spades that goes to the tacometer.. I'm wateing for my ISSPRO tac to come in. I am going to use the 3 3/8th tac. I have the wiring in placed but haven't hooked them up untill I get the tac. I also have the cup mounted. So when the tac gets in I'll wire the tac then pulg the wires in the truck harness.
Old Sep 8, 2003 | 11:00 PM
Monty's Avatar
All first gens with the crank sensor harness installed will be in the location that Ralph (olehippie) mentioned. I believe they started putting them on in 91.5 or 92
Old Sep 8, 2003 | 11:26 PM
FORDNOMORE's Avatar
the problem I am up against is that the previous owner put in a wire harness from another truck. because of this I can not find the four prong adapter for the tach under the dash that everyone is talking about. Where on the engine is the crank sensor and the wires from it?. Hopefully I can find this. :-
Old Sep 10, 2003 | 01:06 AM
carl20320's Avatar
[quote author=Monty(OkieBroncRider) link=board=9;threadid=19310;start=0#msg182313 date=1063080033]
[/quote]
It is not on my 91.5 D250. I think they started in 92. :'(
Carl
Firebb15
Jul 13, 2009 03:35 PM
Paul Winey
Feb 21, 2003 08:39 AM
buckshot
Jan 21, 2003 12:24 AM
frankie9510
Jan 10, 2003 03:19 PM
Rammer64
Oct 7, 2002 07:17 AM
