important gauges
Old 01-31-2010, 04:14 PM
gwayne919's Avatar
important gauges
Please tell me which gauges are the most important to install in my 1 ton diesel & why?I am referring to additional aftermarket gauges that will help me save trouble later & help to solve running problems.
Old 01-31-2010, 04:17 PM
Greed 93's Avatar
What year is your truck
Old 01-31-2010, 04:23 PM
G1625S's Avatar
Welcome to DTR Go to the upper left of this page and click on usercp and fill out your signature so we know what your rig is. It's hard to say what gauges you need without knowing what you're driving
greg
Old 01-31-2010, 04:29 PM
Pirate's Avatar
The most important gauge in any truck is the under seat gas detector. Lets you know who ripped it and how deadly the fumes are.
Old 01-31-2010, 04:43 PM
gwayne919's Avatar
Sorry guys, thought I had filled out my signature. Let us try again. Oh, BTW, my nose is still my best gas detector.
Old 01-31-2010, 04:45 PM
gwayne919's Avatar
It sure is cold out here
Trying again as a diesel.
Old 01-31-2010, 05:14 PM
annabelle's Avatar
EGT's ,fuel pressure, boost, and tranny temp.
Old 01-31-2010, 06:49 PM
AH64ID's Avatar
For a stock truck I would say, fuel, trans, EGT, boost in that order.
Old 01-31-2010, 06:59 PM
CODODGE2500MAN's Avatar
Fuel, Fuel, Fuel.... Did I mention fuel? Take it from some one that DIDN'T do it this way and paid for it!
If you're Fuel pressure drops, you won't be moving, so your egt (exhaust gas temp) won't be an issue, nor will you be creating boost....
If you're towing and stock I'd get Fuel pressure, Trans, then egt and then boost. The order after fuel isn't really going to matter as you'll probably end up getting those 3 in a package (boost, egt, and trans temp) with an a-pillar pod to hold them. You can do 3 on the a-pillar and one on the steering column or have someone make it so you can do all 4 on the a-pillar w/ fiberglass...
Welcome!
Old 01-31-2010, 07:28 PM
annabelle's Avatar
How much do you tow? If you tow a lot I'd go EGT, fuel, tranny and boost. If you don't tow I'd say fuel , tranny, EGT, and boost.
Old 01-31-2010, 08:03 PM
gwayne919's Avatar
Smile Thanx
So, Fuel pressure,EGT(ex.gas temp) & boost, since I am not running an automatic tranny is what I need. Should these be mechanical or available with sending units & which is best for the buck.
Old 01-31-2010, 08:05 PM
gwayne919's Avatar
I only tow when I am on vacation otherwise I only drive fast.
Old 01-31-2010, 08:13 PM
AH64ID's Avatar
I would go with electrical. They are a few more $$, but I like the simplicty of them.
That is a good setup for towing or playing!
Kman9090
29
12-06-2007 06:43 PM
rip 112
05-08-2007 02:22 PM
coontz0473
17
09-22-2006 03:52 PM
Duckman1993
09-12-2006 07:50 PM
admin
17
05-03-2003 11:45 PM
Quick Reply: important gauges
