i'm gettin weird vibes... t-case maybe
Old 11-27-2006, 07:32 PM
TNutcher's Avatar
Hey guys, excuse the title haha couldn't help
But yeah it started awhile ago.... first from 70-80mph then slipping down to where it is now at 45 to about 60. It does it mostly when the tranny shifts into 4 lockup or even 3 lockup outta OD up till 60. The x-case shifter shakes like crazy when it does it and its loud too.... I'd read once about something in the x-case with the rear seal or bearing or something causing shakes around certain speeds similar to this... I've never gone into the t case or seen one apart so i dont know much about them. If anyone has had this happen or know of other solutions?? I doubt its the tires, no cupping or funky wear on them and at good pressure, good tires too not soft muds. Its drivin me CRAZY lol please help! Thanks,
TNutcher
Old 11-27-2006, 07:56 PM
TIMMY22's Avatar
check
1. u-joints on front shaft.
2. sometimes the big nut on yoke will be loose.
Old 11-27-2006, 10:48 PM
TNutcher's Avatar
yeah i found a bad u joint.... its closest to the tcase on the main driveshaft. both the nuts are tight.... thanks i'll swap it a.s.a.p. and get back to ya
TNutcher
Old 11-29-2006, 05:54 PM
TNutcher's Avatar
Right on thanks TIMMY22! haha cant believe i missed it but thanks no more vibrations!
TNutcher
Old 11-29-2006, 06:50 PM
TIMMY22's Avatar
no sweat.
nice when it's a cheap fix.
Dhorn33
11-09-2007 02:22 PM
hobbes2
02-05-2007 06:14 AM
HDBeauty
04-25-2006 02:29 AM
BEHRMAN
34
11-28-2004 09:05 AM
angleiron
11-19-2003 07:54 PM
Quick Reply: i'm gettin weird vibes... t-case maybe
