Ignition switch
Old 06-25-2007, 12:40 PM
andyr354's Avatar
Ignition switch
Is the process for changing the switch on a 93 about the same as a 98? Just did one on a 98 and it was easy. Remove cover, 3 x T20 torx, turn key to run, and pull it out?
My 93 is getting to where I have to move the switch around to get the power windows to work. I guess 220K miles of starts and stops is all it could take.
Andy
Old 06-25-2007, 03:18 PM
Yep, same column.
Old 06-25-2007, 06:52 PM
Bruce M's Avatar
Is the Ignition Switch on a 93 the same as a 91??
Old 06-25-2007, 09:34 PM
92DuallyCTD's Avatar
Yep, same column.
This would be only if both are tilt or both non-tilt, correct? Then Dave, do you think a 97 clockspring w/cruise might just fit a 92? I referred an ebay part to another member w/cruise problems. What do you think?(please disregard hijack attempt)
Old 06-25-2007, 09:44 PM
DTR's 'Go to Guy'
vzdude's Avatar
Different parts on the clockspring. Sorry. Kinda rediculous on the price though huh?
Old 06-25-2007, 10:16 PM
andyr354's Avatar
the ignition switch is plenty pricey to.
Cowhand
09-21-2004 10:42 AM
jman
08-25-2004 05:15 PM
jd03ctd
05-10-2004 08:06 AM
GaCamper
12-01-2003 08:59 PM
D4Fritz
03-16-2003 03:55 PM
Quick Reply: Ignition switch
