ignition switch problems?
Old Apr 7, 2008 | 12:39 AM
hardheaded's Avatar
im so stumped yall.... my truck will only work if you run a jump wire to the ip solenoid makin everything tied to it hot, if you unplug it i have a dead truck, nothing... i have to unplug the battery every time i wanna kill the truck.
also, even with a wire jumped to the solenoid my alternator is not charging, i accidentally left the battery plugged in and everything stayed hot draining my battery. i jumped it off with my other truck then took it for a spin to charge the battery up, killed it, ate my lunch, then came back to a dead truck. what could this be?
Old Apr 7, 2008 | 05:19 PM
Could be the ignition switch, but I'd suspect a fusible link before that.
kawi600
Dec 27, 2014 02:06 PM
mike wolfe
Aug 21, 2013 07:11 AM
racer8188
Jan 20, 2011 11:28 AM
D4Fritz
Mar 16, 2003 03:55 PM
