Idiot with an install question
after a pointless 20 minute conversation with the boys at a nationally known truck parts dealer and waiting online for 30 minutes with Edge I seek your assistance.
i bought the edge juice w/ attitude for my 06. the instructions are very detailed until after the 3rd or so step. does anyone have a dumbed down install guide or know of one online. im not sure what the turbo timer/data link cables are and the pictures are too vague for me to figure them out. im just not certain which connectors go where. i managed to get the injectors hooked up and the unit grounded but the next two steps threw me for a loop. thanks.
this on also stummped me for a minute. Get the edge connection ready and than do a head dive under the dash While lying on your back look up the steering column. There is only on place that it can be plugged into. If you have any questions shoot me a pm
The data link cable is pretty self explanatory, look under the front edge of the dash and you will see it. Turbo Timer connector is a different story, I located it but had a hell of a time with the connectors. Basically your working blind with your fingers stuck under the steering column cover. The best thing to do is remove the cover on the column. There is a t15 torx screw deep in a slot on the cover that needs to be removed, once that is out it snaps off. Makes it so much easier when you can see the plug.
Mike
Mike
Mike
Mike
chuxtruk
07-06-2007 09:20 PM
crossy
12-03-2002 06:02 PM
