identifying dana axels
Old 11-24-2010, 07:06 PM
Unless it's untaxed, then it's red.
#2isgreen's Avatar
working on a project truck, a guy in town claim he's selling me a dana 60, but I'm not sure how to make sure it's not a 50. where should i look for a stamp/tag
the 70/80 difference has a bigger tube i know that.
i need to go look tomorrow am any help appreciated!!!
thanks!!
Old 11-24-2010, 08:00 PM
1992gen1_fan's Avatar
On some danas, i think theres supposed to be a number stamped or cast on the webbing on the side of the differential. Thats what i was told by a drive line shop, tho never found one on my rear axle.
Old 11-24-2010, 08:53 PM
PJ 3's Avatar
All Dana Axles have a Bill of Material Number that can be used to determine not only the axle model, but also what components the axle was originally built with. For 2002 and earlier Dodge trucks, the BOM Number is a 6 digit number that begins with a 6 plus a dash number (ex: 605523-3) The BOM number may by stamped on the right axle tube (older axles) or stamped on a tag affixed to the differential cover.
Not all Dana axles have the model number cast on the housing. It can be very difficult to tell a Dana 60 from a Dana 70 as they have nearly identical cover with exactly the same bolt pattern.. One way to tell if you have a Dana 60 or Dana 70 is to measure the cover flange height . The Dana 60 flange height is approximately 1" high. The Dana 70 flange height is about 1¼" high.
Old 11-24-2010, 09:44 PM
#2isgreen's Avatar
wow thanks!
Old 11-24-2010, 10:19 PM
G1625S's Avatar
Agreed with pj 3. Get the BOM and take it to a reputable driveline shop to have it decoded. I've done this a few times and have saved many headaches.
Old 11-24-2010, 10:32 PM
Mark Nixon's Avatar
On the rear Dana 70 3.07 axles, they are identified readily by the machined pads that extend beyond the top and bottom right side (as veiwed from the cover side) of the differential cover.
This is unique to these particular axles, both the early version, '89-'90 and the late version, 90.5 and 91.
Mark.
Old 11-25-2010, 10:09 AM
CaptainChrysler's Avatar
Here is a good place to look up the B.O.M. :
http://www2.dana.com/expertforms/demenu.aspx?prod=AXL
smokeyram
11-28-2006 10:38 AM
2500CTD
10-02-2005 09:18 PM
2500CTD
09-11-2005 07:22 AM
CTDinMT
49
11-17-2003 11:07 AM
JImbo1
09-01-2003 10:38 PM
Quick Reply: identifying dana axels
