IAT sensor
Old 04-04-2007, 09:22 PM
WVU Dodge's Avatar
IAT sensor
I was reading about checking the intake sensor on the board. Mine was a little bit dingy but not bad, so i cleaned it up. I checked the resistance across the two prongs on it and got 8,000 ohms. And I also got 5 volts at the harness feeding it.
Now i think that i read somewhere what the resistance should be at different temperatures, but can't remember where i found it. It was about 75* when i checked it. But the Haynes manual was telling me that i should be reading 12 volts at the IAT and only 5 at the MAP sensor. It didnt give me an ohm reading for it. And I was reading only 5 volts at each one. does that mean i have a problem or was that a misprint, b/c both get power from the PCM (or ECM) as i understand, so i would think it should be the same at both sensors, but the Haynes manual is telling me I have a problem.
Truck runs fine, I was just piddling seeing if i can get a couple more miles per gallon. I'm getting about 16 mpg by the way with 5spd, 4.10's and 35's.
Adam
Old 04-05-2007, 03:38 AM
Philabuster's Avatar
Cummins IAT Sensor
Deg F ohms
30 40k
32 30-36k
76 13k
77 9-11k
81 6.87k
122 3-4k
130 4k
167 600-675
212 600-675
https://www.dieseltruckresource.com/...d.php?t=136583
scottboy69358
07-04-2013 02:05 AM
supr
18
05-21-2007 09:29 AM
Shepherd57
05-05-2003 05:04 AM
TX Ram
02-26-2003 10:38 PM
bkay
01-17-2003 03:30 PM
Quick Reply: IAT sensor
