IAT Sensor-what size socket?
Old 08-06-2005, 12:56 PM
mamm7215's Avatar
I've got a 2002 and can't figure out what size socket to use. My tool kit isn't the greatest but Fritz's site said 13/16 but it's too small to get over the black female part. I'm going to have to get a deep well but does anyone know offhand what the size is? I'm going to clean it.
Thanks.
Old 08-06-2005, 02:00 PM
Dr. Evil's Avatar
13/16" or 22mm DEEP. Ive used both sizes. Would be an idea to check the resistance at different temperatures:
http://www.dodgeram.org/tech/dsl/sensors/IAT/clean.htm
Old 08-06-2005, 02:19 PM
smokindog's Avatar
Isn't it the same size as the MAP sensor? 1 1/4" did the trick for me.
Old 08-06-2005, 08:37 PM
Dr. Evil's Avatar
not sure the size of the map sensor but the IAT is definitely 13/16" deep....Ive got an exhaust brake and have cleaned mine many times.
Old 08-07-2005, 12:28 AM
mamm7215's Avatar
It's definitely bigger than 13/16"
Old 08-07-2005, 12:30 AM
mamm7215's Avatar
Although, once the grey male connector comes off, there's still a black female plastic plug on top of the hex. The 13/16 I tried got stuck on this , maybe I should have pushed harder?
Old 08-07-2005, 08:29 AM
Mopar1973man's Avatar
I agree with Dr. Evil it's a 13/16 deep well socket it remove the IAT sensor.
While your at it you might as well pull the MAP sensor too and give it a quick cleaning too..
Old 08-07-2005, 09:25 AM
Dr. Evil's Avatar
I dunno - I use a 12 pt socket - maybe you are using a 6 pt?? "could" be different tolerances on sockets??
Are you guys sure youre looking for the IAT in the right location??
Old 08-07-2005, 10:53 AM
mamm7215's Avatar
I was using a 6 pt impact socket (not with an impact wrench btw!). Yeah, I've got the service manual and it's definitely the IAT sensor.
Old 08-07-2005, 11:54 AM
Dr. Evil's Avatar
I would try a thin wall regular socket
Old 08-07-2005, 04:06 PM
mamm7215's Avatar
1 1/16" but in looking at the manual again, it may have been the map sensor. I'm a dumb*ss. Wife's got the truck out now but will double check later. Anyways, pulled the sensor out but the IAT should have a little module sticking out the other side, no? This one didn't making me think I got the map sensor and didn't look far enough back for the IAT. Sorry to get you all going.
Old 08-07-2005, 06:22 PM
mamm7215's Avatar
D'OH, ok it was the map sensor I took out and needed a 1 1/16" socket for. At least it was clean. IAT is smaller and further back so I'll take it out and clean it next. Thanks again for your replies.
M
Old 08-07-2005, 10:12 PM
Sixpack's Avatar
I use a 13/16th spark plug socket to remove mine. Works just fine.
Old 08-07-2005, 11:29 PM
Dr. Evil's Avatar
Glad you got it figured bud...
scottboy69358
07-04-2013 02:05 AM
Scotty
05-19-2011 11:30 AM
BorntoHunt
06-10-2008 09:22 PM
supr
18
05-21-2007 09:29 AM
jrs_dodge_diesel
19
08-03-2006 01:49 AM
Quick Reply: IAT Sensor-what size socket?
