HX40 Wastegate
Old 11-13-2010, 09:55 AM
apwcu's Avatar
HX40 Wastegate
I am putting on a used hx40 on my 91 and it did not come with a wastegate. It is an 8 blade t4 with the 19cm exhaust housing. If I am not running over the limits of the turbo is there a way to just block off the wastegate or am I going to have to buy one?
Thanks.
Also if anyone has put an hx40 on, how did you line up the oil drain line? I got mine on but it leaks because it doesn't line up right.
Old 11-13-2010, 11:39 AM
bgilbert's Avatar
You can tack weld or wire it shut.
Old 11-13-2010, 12:04 PM
D/UNIT's Avatar
Ive cut the drain back tube and installed a piece hose with two hose clamps to get proper alignment.
Old 11-13-2010, 12:59 PM
Douglas2's Avatar
With a 19cm exhaust housing, it seems little risk to wire it shut. Now if it was smaller I *MIGHT* go to the effort of getting a working waste-gate, but it would probably depend on what maximum pressure you wanted to see. If you don't want to go over 30 psi a WG is probably called for.
cheers,
Douglas
Old 11-13-2010, 05:23 PM
apwcu's Avatar
Ok that's what I will end up doing. I don't even know how a wastegate hooks up to the turbo, but I do understand how it works and what it's for. What exactly do you wire shut? I've already put the turbo on, can you do it without taking it off?
apwcu
03-08-2011 06:25 PM
Smokin Flatbed
11-30-2006 01:49 AM
ataboy9026
02-22-2006 05:09 AM
MoparRiggan
10-13-2005 11:54 AM
Hawkeye
09-23-2003 08:22 PM
Quick Reply: HX40 Wastegate
