Hx40 exhaust housing question
Old 04-26-2007, 05:28 PM
schoust's Avatar
What is the smallest exhaust housing that can be used with this turbo? Just wondering in case I get one I would love to move more air but keep lag to a minimum with an older turbo I don't know if it is even posible??
Old 04-26-2007, 06:47 PM
cyric's Avatar
I believe a 16cm2 housing is as small as you can go unless you have someone modify a hx35 14 cm2 housing. Somebody will correct me if I am wrong.
Joe
Old 04-26-2007, 08:05 PM
Ryan's Avatar
There is a 14cm wastegated exhauste housing that will directly fit an HX40. It is from a Volvo application. It does require some custom exhaust work as it does not use the standard HX40 flange to the down pipe.
Old 04-27-2007, 07:02 AM
signature600's Avatar
I have a 14cm HX40 out let housing for one...pm me for more info
Chris
Old 04-27-2007, 11:19 PM
CL2000's Avatar
I had a piers 40 with a 16 and it lit off a lot better than a 35
Dean Snow
11-18-2010 07:35 PM
wyomingpower
04-30-2010 04:25 PM
1320
12-06-2009 02:07 AM
Tartarus
12-08-2003 04:55 PM
Hawkeye
09-23-2003 08:22 PM
Quick Reply: Hx40 exhaust housing question
