hx-35 12cm or16cm housing
Old 06-26-2007, 07:37 PM
goronimal's Avatar
I have a 16cm and the 12cm housing for a hx-35 turbo.I was wondering if anyone had any input on witch one was better to use. I have a `93 ram 350 auto tranny,3.5 to 4in open exhaust,plannin on fuel pin and 3200 spring in the near future.Thanks for any input.
Old 06-26-2007, 08:33 PM
NoSparkplugs's Avatar
With the auto tranny in your truck I'd stick with the 16cm housing. Not much of a difference with the 12cm and 16cm on an auto truck in terms of spool up. Although if the 12cm is wastegated, it is a nice feature to have IMO.
Before I forget, do you have gauges? I wouldn't recommend tinkering with the fueling and turbo setup until you do.
Lucas
Old 06-27-2007, 12:00 AM
MJDiesel's Avatar
I am actually in the process of making the same decision as you are. From the information that I have obtained from this forum, as well as other knowledgable people, I decided to go with the 12 cm housing. The general consensus is that it is the best for an engine with stock injectors and mild pump mods. One small problem to take into consideration is that a wastegated housing requires that the downpipe be moved back about an inch.
Old 06-27-2007, 11:01 AM
TexasHardcore's Avatar
Get some injectors, gov spring, and fuel pin, run the 16cm2 housing, and try to find a good HX-35 cold side to use as well and you'll be pushing about ~340/~840 at the wheels
Here's my old '92 with a similar setup...
Old 06-28-2007, 11:35 PM
flyingd's Avatar
So where does one find a good used hx-35
Old 06-28-2007, 11:51 PM
Check the 2nd gen classifieds on here. Its where I got mine, came off of a 98' 12v
Old 06-29-2007, 12:04 AM
Micaiahfied's Avatar
unless it all in the injectors i don't see a truck with those mods making 340/840 especially not an auto truck it just wouldn't make it to the ground. i ran 370/840 with pods, gov spring, fuel pin, HTT stage 3 (slightly larger than 35 wheel), AND water meth... i was at 310/725ish without water meth.
Old 06-29-2007, 12:17 AM
goronimal's Avatar
Thanks for the info,I`m gong to run the 16cm housing.Does anyone know how mutch up and down play a hx-35 is allowed to have.And what do I hook up the wastegate to.
Old 06-29-2007, 06:32 AM
G1625S's Avatar
As long as the fan blades don't touch the housing, you're good to go. There is no wastegate on a 16cm housing.
Old 06-29-2007, 12:45 PM
okiesmartguy's Avatar
Im running an 18.5 on mine and i just put an hx35 on my truck, it spools a bit slower but the new turbo cooled the blistering exhaust temps.
Old 06-29-2007, 08:43 PM
goronimal's Avatar
So is it better to run the 12cm wg or the 18cm non wg.
Old 06-29-2007, 10:05 PM
dpuckett's Avatar
It depends on your intended use and desires. If you tow a lot with enhanced fuelling, and can live with a little lag, go for the 18. If you run aroudn empty, and/ or tow ight (under 10K), the 12 will be just fine. Run one of each for a month and make note of temps, boosts, etc, and stick with the one you like.
Daniel
ajbirken
09-06-2006 12:11 AM
HOHN
12-07-2003 02:07 PM
cethane
10-29-2003 09:58 PM
nevrenufhp
03-31-2003 06:42 PM
cethane
12-16-2002 11:07 AM
Quick Reply: hx-35 12cm or16cm housing
