Huge oil leak
Old 11-23-2011, 02:21 PM
cwebb710's Avatar
Huge oil leak
Okay i have a 95 12v i got it had a little oil leak but nothing noticeable. I started my truck this morning let it warm up drove about 15miles came home and oil is all over the place and its dripping really bad and the oil isnt on the dipstick anymore
Old 11-23-2011, 03:08 PM
luke03cr's Avatar
check your oil filter, i have seen the o ring seals come apart and blow oil everywhere.
Old 11-23-2011, 03:28 PM
cwebb710's Avatar
I think its the oil pan gasket not 100% yet
Old 11-23-2011, 04:40 PM
rebal's Avatar
could it be your tappet cover? or KDP? vac pump seal?
Old 11-23-2011, 05:06 PM
Hodge's Avatar
You should clean the engine, then determine where it is coming from. Unless you hit something that would damage the oil pan, I doubt it would leak one day, but not before. More than likely, it is something else, and just looks like its coming from the pan. Oil runs downhill, and the pan is on the bottom. If you have oil anywhere above the pan, then you know that isn't culprit.
Old 11-23-2011, 05:41 PM
green95's Avatar
I agree with above, Clean everything as well as u can(plenty of bio degradable cleaners out there). If it isn't profuse enough to see happening Hit the local parts store and see if they have a leak tracer kit,usually some dye to add and a batt. powered black light,you'll find where it's originating from.Have you done anything recently,oil change perhaps?
Old 11-23-2011, 06:28 PM
cwebb710's Avatar
Okay guys thanks for the responses. Haven't done anything to it just got the truck last week. Haven't hit anything theres no oil above the pan the only oil marks are from the back of the serpentine belt from going where the pan begins an picking up oil on the belt(would explain the little squeal too) picked up a gasket for 20 bucks needed an oil change too so i will keep updated tomorrow if it continues
Old 11-23-2011, 08:03 PM
whiskers's Avatar
Clean it as well as you can and spray baby powder everywhere you can get it . It will show the oil trails very well.
Old 11-24-2011, 10:25 AM
cwebb710's Avatar
Okay so i was wrong with my whole diagnosis My timing gear case has a huge chunk missing out of it ill post pics in a bit. I think my KDP droped but im not sure of where its supposed to be or what it looks like need a little bit of research on here. First how do i replace the case i have to pull all the gears i know that but anything i need to make sure i do to be able to put it together and have a running truck in the end?
Old 11-24-2011, 10:36 AM
cwebb710's Avatar
The chunk missing and the cover
Old 11-24-2011, 10:47 AM
cwebb710's Avatar
Yepp just did research an looks like i have to pull my whole camshaft cause its the inner case glad i just put the truck on the road an haven't had it for a week gahashashsahcdhdhdhshlsdahfd
Old 11-24-2011, 01:07 PM
chariotdriver's Avatar
Just pull the camshaft gear with the special puller. You'll need to heat it up to get it back on. I've done it both ways on a couple friends trucks, pulling just the gear saves about 8 hours and you don't risk dropping a tappet into a very bad place. Your pin is either out the hole you now have or dropped to the bottom of the case/oil pan. The pin is about 5/16" by 5/8" long give or take a few mm's. An unbelievable ***** in the armour of such a great engine.
Old 11-24-2011, 06:43 PM
cwebb710's Avatar
Okay any ideas where i can get this special puller and all i need is to pull the cam shaft gear?
Old 11-24-2011, 08:15 PM
whiskers's Avatar
Had this happen on a '97. Blew the whole top out of the case. I was on the road. Went to an auto parts, bought a couple packs of 5 minute J$B Weld. Used some plastic out of the dumpster to bridge gaps where I couldn't find thew pieces to fill them. Pasted that dude up with JB and waited 30n minutes for it to cure. Drove that truck another 100k and sold it to the next guy and as far as I know it's still the same way. If the piece is not a load bearing spot, glue it up and drive on. Jb Weld holds in high heat. we use it all the time to modify cooling ports on jeep head c onversions. Great stuff.
Old 11-25-2011, 12:10 AM
cwebb710's Avatar
in pics above i don't know if its a load bearing spot or not im thinking jb wled it an hope for the best. seems like its a big piece to jb weld tho
Quick Reply: Huge oil leak
