hpfp 95 vs raptor 100
I just installed the fass ddrp the other day, took a little engineering to get it to fit the vulcan relocate kit bracket (seemed like it should drop right in stock location).....but I can't pull fuel pressure below 14psi at wot, 16-17 lbs at idle.
we have the same setup other than my 275 injectors....might be worth looking into to save some $$$.
Our Carter relo bracket is NOT designed for use with the DDRP. The DDRP bracket is heavier and has the correct holes in them.
Dave
Dave
I just had a FASS 150 put on my rig a month ago and have had no problems. Idle at 21-22 and no lower than 14 pounds at WOT. only 450 $ for the hole set up. Same price as the FASS 95 too so figured, bigger is better for mods down the road.
53 willys
38
11-06-2008 11:18 AM
jmccart
01-28-2008 11:26 PM
84mphcdt
16
12-19-2007 11:31 AM
