hot juice?
Old 08-31-2007, 02:47 PM
cb's dodge's Avatar
hot juice?
I am deciding weather to get the hot juice unlock or not? is it worth it and does it blow any more smoke than the extreme setting?
Old 08-31-2007, 03:22 PM
Jordan5687's Avatar
I'd like to hear about this too, was thinking about doing the same if the dollars to power figure out good enough.
Old 08-31-2007, 03:36 PM
Proud Rebel's Avatar
Yea ditto!
Old 08-31-2007, 03:59 PM
GrizzlyAdams's Avatar
It has a quite a bit of smoke...Great power if you can keep your EGT's down.hit 1400 in no time..
Old 08-31-2007, 04:11 PM
Jordan5687's Avatar
Big difference between that and level 5, or not too much???
Old 08-31-2007, 04:19 PM
BBarnett's Avatar
Huge diff. Level 6 blows lots of blackness on the bottom. It is well worth the upgrade...
Old 08-31-2007, 04:21 PM
Jordan5687's Avatar
How much is the upgrade? and did you have to send it in or did they just give you a code??
Old 08-31-2007, 04:26 PM
cbrahs's Avatar
I think it is $100. If I recall correctly.
$oC@l CTD's Avatar
On your 2001, it does't add ANY hp or tq to your motor getting the Hot unlocked...it only raises your defueling from 2700RPMs to 3200...so you won't notice any snappier take off or anything like that...just a longer power curve...I wouldn't think it would be worth the $100 and time with the Edge off your truck and sent in to Edge to be unlocked if you ask me...if you want more power look for something good to stack with. Just my 2 pennies
Old 08-31-2007, 04:34 PM
Jordan5687's Avatar
What about a 3k governor spring? How much are those?
Old 08-31-2007, 06:13 PM
BBarnett's Avatar
To unlock call edge and get the code..
I git mine for free, but I think its 100.00
Old 08-31-2007, 07:24 PM
$oC@l CTD's Avatar
He doesn't have the luxury that us 06-07 guys have of just calling in for an unlock code...05 and older have to send their units in for programming
Old 08-31-2007, 09:53 PM
skynyrd's Avatar
i can speak for the 05 guys its worth that 100 buck and sending it in stepped up the power a good bit. it does blow a good amount of smoke with a pressure box hooked up as well.
Old 09-01-2007, 04:30 AM
I'm curious to know just how long before the tranny goes out on you and what kinda numbers are we talking about, on the average, for the Hp thing?
Old 09-01-2007, 09:52 AM
cb's dodge's Avatar
how do you go about getting the code?
Quick Reply: hot juice?
