Homemade Meth Kit Help
Been searching around for a while at some of the posts on homemade kits and have what i think is all the info...minus one piece.
All the posts i see use a Hobbs pressure switch, so it sprays at said boost.
I am more interested in having it activate based on EGTs(maybe being able to switch back and forth from boost to EGT would be better), but im at a loss. What do you use for a temp based switch that can handle the extreme heat.
Im sure its staring me in the face but i cant see it.
Thanks in advance
Thanks in advance
I'm not an electronics wizard, but I'm gonna take a stab at it. The EGT probe works off resistance. If you had a "trigger" that was set for a certain resistance, it would work. If not, go with a Snow stage 2 that has that all done for you. Also the Striker kit. I know you want it homemade, but that sometimes becomes the hard route.
If I knew what kind of thermocouple it was (j or k) I could get the calibration chart from work and tell you what the resitence is at what tempture. That might be a start.
I am very interested in this also! Power on a budget I call it! I have been looking at this http://oilburners.net/articles/splash.htm it looks promising and I believe that I can adapt it to our trucks? What do you guy's think??
Thermocouples do not work on resistance, they output a millivolt signal based on the temperature of the junction. How Thermocouples work
What you need is an amplifier to amplify the small millivolt signal to 12 volts so that you have enough current to energize a relay.
There are products that can do this:
This is a panel meter that displays temperature. You can plug a relay into it that will trip when a preset is reached.
Panel Meter
This is a temperature controller that will also close a relay contact when the temperature is reached.
Temperature controller
Panel Meter
The problem i see with a bigger turbo is with the amount of lag can cause extreeme EGTs at a very low boost where a hobbs activated system may fall short.
The goal is to allow for a two stage setup. One stage run off of boost pressure (most likely 15psi), the other stage run over "X" EGT.
Maybe im looking at it the wrong way
Well if you figure somthing out let me know because I will definetly need some sort of Meth injection on my truck because lag will be a bit of a problem for me if I end up with either of the two turbo's I am looking at!
svanni
50
06-16-2007 01:13 PM
S.Dodge
10-11-2006 07:11 PM
n0ne
10-04-2006 12:50 PM
