View Full Version : ho injectors
BlackSheep
05-12-2003, 09:22 AM
were can i get high output injectors for my 98.5 24v and how much are they and do i need other mods to run them?
StakeMan
05-12-2003, 09:39 AM
There are several companies that make bigger injectors for your truck.
ATS Diesel performance
Wildcat Diesel
Just to name a few that are advertisers on the DTR.
how much are they
That depends on how much HP you are after. I would say that most are between $500 and $1200.
Again, that depends on how much hp you are wanting. I would suggest gauges even on a stock truck. If you are looking for a mild setup I would get a timing box such as a Power Edge EZ and some small injectors (50-60 hp). A Wild setup would be a major fueling box and some huge EDM injectors. The bigger the HP the more thnigs you will need to use that power, ie exhaust, turbo, intake system.
KatDiesel
05-12-2003, 10:47 AM
Don't forget you'll most likely need new connecting tubes (adds about $75)
Don M
JR Adkins
Diesel Dynamics
BullyDog
Those are some vendors with injectors. Mild to wild.
BlackSheep
05-12-2003, 02:26 PM
i think im going for the mild i just want a little more getup than i have right now, and im looking for cheep things right now
StakeMan
05-12-2003, 05:18 PM
If your just looking for a little HP then find an EZ for sale. It makes a big difference in the way the truck runs. After the bomb bug is in your blood you can add injectors and you already have the boost fooler.<br><br>Thats the same thing I did.<br><br>I thought the EZ was great and would be all the power I would want. Then I upgraded to a PE Comp. Automatic didn't like that so I upgraded. That was fun for a while. Then injectors, turbo, exhaust. Still looking for more. ;D
