highest horsepower 3rd gen with stock fuel system
Old 07-22-2007, 08:13 PM
rattlbox's Avatar
what is the highest horsepower 3rd gen with stock cp3,stock in tank pump and stock fuel lines?
Old 07-22-2007, 09:38 PM
dieselfan's Avatar
you should have posted this in the high perf. section, it gets more traffic.
Old 07-23-2007, 01:03 AM
TexasCTD's Avatar
Mine had the filter housing mounted fuel pump that "sucked" the fuel. But I made 466hp with the Smarty on 9 with it. Fuel pressure was zero or close to it though.
After adding the GDP Walbro I made 467 on a different dynojet.
I don't think my stocker FP would have provided any more fuel to make more power though....or certainly not much more. The intank pumps probably provide a little better pressure and supply though.
Old 07-23-2007, 06:31 AM
Muted User
Sprinter17's Avatar
Probably more than you could make horsepower for, and if you did make more HP than that , you'd change the fuel system because resources obviously are no object.
Old 07-23-2007, 09:42 AM
03qclb5spd's Avatar
The numbers in my sig were on a stock system. I have since added a fass system. I will dyno again to see if there is any difference.
Old 07-23-2007, 01:18 PM
dieselfan's Avatar
were you draining your rail psi? or fuel psi?
Old 07-23-2007, 01:56 PM
03qclb5spd's Avatar
Problem is I did not have anything to monitor those pressures during my dyno runs. I only recently got the Quadzilla RP/FP gauge, and that was after the fass system so I will never know what they were on the stock system. I know my fuel psi had to be dropping to 0, I just don't see how it wouldn't at my fueling level. As far as draining the rail I still get some cut out with my tst box on, but it's not quite as severe as it was prior. Time for a modded pump....
Old 07-23-2007, 04:44 PM
Luvnacumns's Avatar
571 and 1021.. ON stock fuel system!!!
Old 07-23-2007, 05:03 PM
dieselfan's Avatar
you didnt have the glacier fuel pump on there?
whats was you rail and fuel psi like?
Old 07-23-2007, 05:34 PM
Luvnacumns's Avatar
Nope... Didn't have rail hooked up at the time of the run but before that on wot runs around town it would hit 23-23.5k and fuel pressure was down to 3..
anonymous_1
13
04-30-2020 04:29 PM
rattlbox
28
07-25-2007 12:39 AM
1qckdodge
03-05-2007 09:53 AM
nick_domingo
06-10-2004 08:59 AM
latitud_rt
07-22-2003 07:55 AM
Quick Reply: highest horsepower 3rd gen with stock fuel system
