High tech turbo hx 35/40 turbo
Old 04-19-2004, 09:50 PM
OldSmokey's Avatar
I am just wondering if a hybrid turbo would work well with an edge comp and either dd 2's or edm 2's. I do tow an 8000 5th wheel every now and then. Also what exhaust housing should be used 14, 16, 14 wastegate or any thing else.
Old 04-19-2004, 10:23 PM
PourinDiesel's Avatar
14cm non wastegated.
--Justin
Old 04-20-2004, 11:14 AM
vssman's Avatar
I run the stage 3 upgrade with my original 12cm housing... No lag at all and worked well with my 300's and #4 plate (Not towing as I don't have anything to tow yet).
Old 04-22-2004, 04:53 PM
ddestruel's Avatar
Location: Used to be missoula, montana: Now in Sonoma County California
I have the stage 3 with a 16 non WG works awsome when towing, a little laggy in certain situations but the better flow is worth it.
Old 04-22-2004, 05:22 PM
Bob Wagner's Avatar
14 wastegated would be a great choice
Old 04-22-2004, 08:23 PM
Haulin_in_Dixie's Avatar
I am in need of a 16 ex housing for a HX35 if anyone has one sitting around, PM me.
Old 04-22-2004, 08:48 PM
mooseman's Avatar
i want to try a hx 35 in place of my hy 35.but i cant seem to find one. is an hx going to be alot better than the hy. if anyone has a hx kicking around pm me.
thanks mooseman
Old 04-22-2004, 10:46 PM
BPonci's Avatar
I agree with Bob W. a 14 housing would be a great ballance between low end spool up and top end egt control.
Old 04-22-2004, 11:50 PM
Muted User
kyle@ftlb's Avatar
moosemen, i'm running the stock hx-35 off an 01 HO and it really makes the truck run a lot smoother it feels like. you will like it. plus you should be able to find one for cheap that someone has replaced. also who did you ahve to do your suncoast tc/vb
Old 04-23-2004, 05:49 PM
mooseman's Avatar
kdawg62, I had it installed at carls accurate in logan. i called down to you guys at gillett and talked to rich. he told me to have carls do it for me rather than drive the miles. carl has always been a freind of mine so he gave me a great deal plus done an excellent, fast job.
mooseman,
Old 04-23-2004, 05:54 PM
mooseman's Avatar
wils, sounds like a good deal that i shouldnt pass up. gime a call as soon as you are ready to bolt it on. theres nothing like members helping out other members is there. maybe someday i can return the favor.
thanks, mooseman
Old 04-23-2004, 05:58 PM
And if you end up with an extra flange type turbo elbow, I will be interested.
Old 04-23-2004, 10:58 PM
Olee Poole's Avatar
the Dodgezilla 14 wastegated turbo would be the way to go.
Old 04-24-2004, 11:26 PM
1dslram's Avatar
The 14 wastegated is the ultimate way to go less lag and better high end flow. It is expensive but well worth it. Otherwise I suggest the 16 non wastegated for now and upgrade later and sell the 16.
Bruce
Quick Reply: High tech turbo hx 35/40 turbo
