High rpm before gears will shift
Old 06-03-2010, 09:52 AM
Joe Backflow's Avatar
I have a 2007 Ram 3500 4wd. Just recently it sticks in 2nd gear way too long. Sometimes up to 3400 rpm before it will shift. When it does shift, it doesn't slam into 3rd... its smooth but just, obviously not at the right rpm. The same happens from 4th to 5th. There is no slipping just shifting into those two gears at the wrong times. Anyone have any experience with this? I have 115k miles on it...
Old 06-03-2010, 09:59 AM
annabelle's Avatar
5.9 with 48 RE?
Old 06-03-2010, 10:01 AM
Sorry new at this. I don't know. How do I find out which one I have?
Old 06-03-2010, 10:11 AM
annabelle's Avatar
Early build date in 06 or late in 07? You need to take your VIN # to the Dealer and get a build sheet so you know what you have. Engine,tranny and gears to name a few.
Old 06-03-2010, 10:13 AM
Thanks.... Late in 07. One of the last three 5.9's in the U.S. available before the 6.7 liter
Old 06-03-2010, 10:24 AM
annabelle's Avatar
You don't have a 5th gear.....most likely you are showing the first sighs of needing a gov. pressure solenoid and sensor. Order the upgraded Chevy version online. Easy to replace.....you will need to drop the pan though......so change the fluid and filter while you are at it
Old 06-03-2010, 10:36 AM
Ok... Thank you so much. Obviously Im VERY new at this. I appreciate it!
Old 06-03-2010, 10:38 AM
annabelle's Avatar
Good luck......you may want to wait for some other opinions......some guys on here are more knowledgeable than I.
Old 06-03-2010, 08:53 PM
2007 5.9's Avatar
Exactly ^^^^^^
notw
26
04-02-2019 04:47 PM
Hopper
04-05-2007 10:09 PM
93beater
02-28-2007 09:28 AM
walexa
30
04-08-2005 10:26 AM
fishin fever
02-22-2004 08:32 PM
Quick Reply: High rpm before gears will shift
