high idle
Old 11-29-2003, 10:04 AM
CurtisvilleCummins's Avatar
high idle
Run away idle, goes up to 2000 rpm and slow to come down. I got 3k gov, 0 plate, 370's, what do u think. I losened the gov springs couple springs and it came back down. i dont know how they coulda got tight. thank you for any help
Old 11-29-2003, 11:16 AM
Ramflasher's Avatar
Re:high idle
I can't help you with any advice, but you might consider re-posting this in the HELP! forum...runaway can be serious.
Or you could email/PM a moderator and have them move it.
Old 11-29-2003, 11:36 PM
HammerMTB's Avatar
Pump trouble
I'd get that pump into a shop right away. If the governor section goes away, your rack could go wide open with no way to shut it down. Something in there has changed, or it wouldn't have hung up. It also wouldn't have responded to your backing off the springs. Sometimes its best to let the pump specialists fix it. MHO, anyway...
Old 11-30-2003, 08:00 AM
Re:high idle
thanks had a stumble at 1200 to 1500 rpm thought tighten gov.spring might help was fine for couple days,then rpm just off,loosened the springs coupleclicks,seems to be ok would like know if anything affects the idle, thanks
90 power ram
03-15-2011 09:37 AM
kicker210
12-02-2009 08:23 AM
cwrhnr
05-19-2009 05:18 PM
jmccart
06-12-2007 02:12 PM
dieselnewbie
01-18-2005 10:48 PM
Quick Reply: high idle
