High idle box activation via remote WORKS
Old 05-03-2007, 07:19 PM
fade94's Avatar
WOO HOO
It took 4 relays and 2 diodes, but I can now start my truck and kick in the adjustable high idle via my remote start remote. Would have gotten my 2-lo conversion done but I picked up the wrong switch
Old 05-03-2007, 07:21 PM
AggieJustin's Avatar
Now all you need is the auto-drive feature, and your truck may be the next James Bond vehicle. Watch out Aston-Martin, here comes Dodge.
Old 05-04-2007, 11:53 PM
JSPulliam21's Avatar
Where are you getting the components for your 2 low kit?
Old 05-04-2007, 11:57 PM
fade94's Avatar
A buddy of mine has a connection for the vacuum switch. Other than that, you just need a switch and about 6 inches of hose. His ID on here is bnold. The vac switch was $15 shipped. Not sure if his buddy has anymore, but he'll be able to tell you.
Just holler if you need any info.
Old 05-05-2007, 09:49 PM
bigd450's Avatar
what high idle box are you using?
Old 05-06-2007, 01:01 AM
fade94's Avatar
It's a home made box. It has a toggle switch that turns it on and an adjustment **** to set the idle.
Old 05-06-2007, 07:47 AM
J Lent's Avatar
How many ports are needed to hook up a 2 lo switch. I have a vacuum solenoid with 2 ports....will that work? I believe Bnold said a 3 port solenoid was needed, but not sure.
Old 05-06-2007, 09:48 AM
fade94's Avatar
The switch I have has 3, inlet, vent, and outlet.
Old 05-06-2007, 10:40 AM
J Lent's Avatar
Are 3 ports needed? Do they all hook up to vacuum lines? My friend has a stockpile of 2 port solenoids.
Old 05-06-2007, 11:32 AM
fade94's Avatar
One port is for the vacuum line from the supply. The second port is for the line that runs to the axle. The third post is a vent. Not sure if it's needed. As long as you can supply power and stop the flow of vacuum, your switch should work.
Old 09-19-2007, 08:34 PM
bnold's Avatar
don't know how I ever missed this thread, but to answer your question I think a 3 port is needed... that way once you flip the switch to cut vacuum the vacuum stored in the line can be vented... otherwise you may have enough vacuum in the ine to get partial engagement which would be a bad deal!
Old 09-20-2007, 01:24 PM
fade94's Avatar
What he ^ said.
elephantrider
01-30-2012 09:58 AM
tesla440
23
10-05-2009 06:05 AM
jthorpe
19
09-18-2007 12:03 PM
high country
03-07-2005 12:37 PM
Quick Reply: High idle box activation via remote WORKS
