High EGT's
High EGT's
i went to run at the race track last night with my new combo of the smarty and the quad my egts were pegged at 1500 degrees. i had the smarty on se6. what do i need to do to lower my egts what do u guys suggest
1500 degrees isn't the end of the world. Unless that's what your egt gauge maxes out at and you really don't know the exact high temp number....? And the super B special should bring temps down considerably but I have no idea about towing... But you shouldn't even notice a 4' trailer... unless you meant 40'?
Depends on elevation, a 64 at 2300' max around here tows well with a stick. Your auto may lag a little more but if you are in the 5,000 ft or more elevation you may not like it.
jmccart
03-18-2007 10:03 PM
jmccart
11-20-2006 06:45 PM
