hi first question reguarding suspension
Old 08-15-2011, 10:25 PM
topbanana3767's Avatar
Well Hi everyone my first post . My question is as follows , on my 2010 2500 diesel o have stock 265 tires. I have a leer cap and a leveling kit up front. My truck is.pretty much flat what ovwould like to do is add A spring to the rear for a little pitch .any ideas on what to get and where ? Thanks for your response on advance.
Old 08-15-2011, 10:41 PM
Danderson's Avatar
Some Firestone airbags would give you back the pitch you desire.
Old 08-17-2011, 09:23 AM
Skyd Ram's Avatar
You could add a set fo Carli mini packs to get about an inch of lift. Plus it will right a bit better.
Old 08-17-2011, 05:35 PM
Where's a good place to pick up a set
Old 08-18-2011, 10:51 AM
.boB's Avatar
So... you put in a leveling kit to remove the pitch. Now you want to add additional springs in the back to regain the pitch. Why not remove the leveling kit?
Old 08-18-2011, 11:16 AM
S.TX.MEGA's Avatar
THANK YOU boB, some common sense. Thats exactly what I was going to say as I was reading the other replies.
Old 08-19-2011, 01:23 AM
hi bob well that would be a valid point , but had you actually asked why instead of taking an opportunity to take a shot . the answer to you would have been is i plan on going with larger tires and need the wheel wheel room. so i thank you for your advice and opinion but i do believe there is an old saying about opinions ?
Old 08-22-2011, 09:21 AM
.boB's Avatar
That's why I asked, "Why not...?" It wasn't a cheap shot, it was just something that wasn't clear. If you want an intelligent asnwer, you have to supply enough info.
I would use a simople spacer block. For 1-2" They are perfectly safe, cheap, quick, and easy to install. You will also maintain the stock ride qualities.
The more you arch the spring, the harsher the ride can become; especially when empty. You could put extended shackles. But they're a lot more expensive, and more difficult to install. The have to be pretty hefty to prevent lateral flex.
atown
06-07-2011 07:53 PM
mtnman006
24
09-08-2009 03:14 PM
Troutstrannysvc
04-04-2007 06:54 PM
Linda
Off Road / 4x4
24
01-09-2007 10:12 PM
Quick Reply: hi first question reguarding suspension
