HELP valve adjust
Old 01-03-2007, 10:42 AM
Micaiahfied's Avatar
HELP valve adjust
this is my first time doing a valve adjust and it was going smoothly. i used the timing pin to find TDC for #1 and followed the instructions. .010 intake and .020 exhuast.
adjusted #1 I&E #2 I #3 E #4 noticed that the valve spring was VERY compressed... i am trying to gap it but cannot get a .010 gap even with the adjuster all the way out? what is the deal? #5 E looks like it is the same way... i'm stuck what do i need to do?
Old 01-03-2007, 10:46 AM
at this point the exhaust valve for #4 has over a .020 gap... what is the deal?
Old 01-03-2007, 10:49 AM
paulb's Avatar
You should adjust: Intake 1-2-4, Exhaust 1-3-5
Rotate engine 360* and adjust: Intake 3-5-6, Exhaust 2-4-6
Paul
Old 01-03-2007, 10:54 AM
yea that's where i am having a problem. intake 4 is too tight to even adjust
Old 01-03-2007, 10:56 AM
#5's exhaust spring also looks fully compressed at this point... again i used the timing pin to find tdc on #1... why are these valves like this?
Old 01-03-2007, 01:25 PM
tomd's Avatar
Sorry but I cant help you... Valve adjustments mess with my head to much so I ended up taking my truck to Dodge here in town for a reasonable price. (About a year ago)
Old 01-03-2007, 02:22 PM
paulb's Avatar
In your first post, you said you were trying to adjust #4 exhaust. Was that a miss print?
Old 01-03-2007, 03:25 PM
it actually was ment to be read #3 E then #4... i was explaining what was going on but didn't indicate intake or exhaust. i see that it was consufing. sorry. anyways i found that i could push the timing pin at any time i wanted too, seems i was not all that close to TDC (no wonder they were taking so much adjustment) after doing a quick search and finding that using the alternator when the intake on #6 is rising (closing) and the exhaust just starts to drop, i am going to be TDC on the #1 cylinder. at that point i adjusted according to the directions in the sticky. once i had the motor to the correct position it was simple! i figure my next adjust will take 30minutes.. if i take my time. thanks for the help, truck runs much better. not sure how many of the first 5 i did were out but of the last 7 i had to adjust 5 of them, and 3 were out pretty bad.
Old 01-03-2007, 04:02 PM
Sounds like the timing pin is broke. Looks like you got 'er figured out, though.
Old 01-03-2007, 04:05 PM
Underpsi's Avatar
Speaking of timing pin since this thread is pretty well done anyways, anyone know how to properly adjust it?
Old 01-04-2007, 05:15 AM
59FORD's Avatar
There is no "adjustment" for the timing pin. When you push the pin in
it just goes into a hole in the pump gear, a precise fit.
That is what locates TDC on number 1. Pull out the pin and rotate
the engine 180* and you have TDC on number 6. Remember 2 crank
rotations equals 1 cam rotation.
It is very easy to break the tip off the timing pin. The whole thing
is some type of plastic.
59
Old 01-04-2007, 05:13 PM
Incorrect. The housing the pin mounts in is adjustable.
To reset it if it's been removed, find TDC using the valve drop method, set the crank at TDC, and put the pin in the hole. Tighten the bolts on the housing and you are all set.
Old 01-04-2007, 05:32 PM
flashgordon's Avatar
find TDC using the valve drop method make sure you know what that means, and how to do it, or you timing pin will be the least of you worries
just when't and look in the sticky, couldn't find it! So....just make sure you get a service manual and read up on it be for you begin
Flash.
Old 01-04-2007, 10:35 PM
Underpsi's Avatar
Thanks dave thats all I needed, I thought there was actually some measurements or something for it
STACKED
08-01-2006 10:47 PM
03quadduallyho
06-25-2006 09:32 AM
DieselJoe
04-27-2006 05:06 PM
towin1JT
08-06-2003 09:09 AM
Quick Reply: HELP valve adjust
