HELP...Truck cuts out under power!
Old 08-03-2011, 11:44 PM
Fireman20's Avatar
I am at a loss for ideas here! The truck starts up and idles perfectly, then about 30 MPH cuts out and falls on its face! It even dies sometimes!....Installed a clear fuel line and cant see any bubbles...dont know where else to look!
Old 08-03-2011, 11:45 PM
Fireman20's Avatar
BTW...1992 5.9 swaped into a 1972 GMC 4x4 automatic
Old 08-03-2011, 11:57 PM
Fireman20's Avatar
Installed new filters all around and new fuel lines....Could this be a fuel issue or electrical? Would a seeping number 6 injector cause this?
Old 08-04-2011, 12:29 AM
Administrator/Jarhead
madhat's Avatar
My first thought would be a bad fuel pump. I'd need to know a little bit more about your setup, but you might want to post this in the 1st gen section, they can help you out.
Old 08-04-2011, 12:37 AM
Fireman20's Avatar
Ok...I will try that section. Sorry, first post on the forum
Old 08-04-2011, 08:42 AM
madhat's Avatar
No worries...
Old 09-17-2011, 07:58 PM
TheWaterman1000's Avatar
Check fuel pressure. My 2nd gen did simulair. Changed OFV and ran great...
Old 09-17-2011, 11:14 PM
Onemoparnut's Avatar
I would check the connection of the power wire to the fuel shut down solenoid.
Old 09-18-2011, 09:14 AM
GIT-R-DONE's Avatar
That would be my first guess as well ^^^^^^^^^^^
Old 09-18-2011, 09:15 AM
JD730's Avatar
Start with this, get the connection secured first, if it still does it you can remove the plunger and spring to eliminate that from the equation and if it still dies it could be broken plunger return springs in the pump, its been known to happen, I had two different pumps do that.
Old 09-18-2011, 11:13 AM
1st Generation Admin
BC847's Avatar
^^ This first.
Old 09-18-2011, 10:10 PM
jimlj's Avatar
I was going to say to check your fuel filter, but it looks like you already did that. It wouldn't hurt, or cost much to install a new filter anyway. I'd also check your lift pump to make sure it is good. A fuel pressure guage is your friend.
Could this be fuel or electrical?? Yes. About the only electrical issue I could think of is the shut off solonoid. An otherwise healthy 1st gen Cummins will run if it is getting fuel and air.
I don't think a seeping injector will cause more than a miss and or wasted fuel.
A Cummins in a GMC?? Isn't that like a diamond in a goats hinder?? Just kidding, sounds like a cool truck.
Old 09-18-2011, 10:39 PM
Stomp's Avatar
My guess would be lift pump. When mine started getting weak this started happening.
Stomp
Old 10-16-2011, 03:05 PM
RICHD903's Avatar
AMEN, to checking the power lead to the solenoid, this weekend my 93 would build 5lbs of boost at any speed then fall on its face. The third time it did it, it died and the connector to the solenoid was very loose, mushed it down with some pliers and good to go.
Old 10-16-2011, 06:51 PM
DodgeFreak's Avatar
Mainly wasted fuel all six of my injecters seep lol doesn't miss...just wastes fuel....
Quick Reply: HELP...Truck cuts out under power!
