??help trans questions
i have a 2004 1/2 3500 drw cummins with the 4 speed 48-re tranns some times when i put it in reverse and give it a little throttle i get a weird clunk like sound and feel same in drive sometimes it happends sometimes it dont i drive with my hot juice around on level 1 when i wanna run it i take it to level 5 then back to 1 my attitude monitor says i get 8% slip when i mash the pedel on the highway on level 3 to get a little smoke last year i was backing a 4000 lbs boat up a steep grade and my trannsmission temp light came on then went off i tow a 13000 lbs 5ver camper sometime my truck has 32000 miles on it does this sound like my transmission is about to chit to bed thanks
Originally Posted by benny
its kinda like its slipping into gear when i put it in reverse and takes a minute to catch
Do a search for "band adjust" or "adjusting bands" and you'll get all the specifics you need.
It is something you can do in your driveway.
You will need an INCH pound torque wrench, a torx bit (not sure which size) for one of the bands, a 1/4" socket for the other band, 2 other sockets for the lock nuts, and one socket for the pan bolts.
Front band adjust: 40torx, 3/4 box end wrench. I like to put a little teflon sealer on inside edge of lock nut to prevent seepage of fluid up threads.
Reverse band: 1/4" socket, 9/16 deep offset box end wrench.
specs: front band, 72 in.lb., back off two turns
reverse band: 72 in.lb., back off 3 turns.
Check fluid before doing anything else, and check in NEUTRAL.
HTH
James
DTT builder/installer
Near Dallas.
HTH
James
Near Dallas.
Les Eid
02-13-2008 09:22 AM
nfsommer
11-09-2007 09:36 AM
djgaston
10-30-2005 03:18 PM
live wire
07-21-2003 07:26 AM
