Help stacking boxes
Old Apr 5, 2005 | 08:32 AM
Jetpilot's Avatar
Help stacking boxes
Ok guys I have a truck I am setting up a 2002 CTD for a friend and he wants to stack a FMS with an EZ. When stacking boxes does it matter which box is plugged into the MAP first (example EZ into MAP and FMS into EZ)? If so which one should be attached to the MAP?
Thanks in advance for the help.
Doug
Old Apr 5, 2005 | 10:22 AM
BigBlue's Avatar
I'd do the FMS then the ez.
Old Apr 5, 2005 | 10:44 AM
Mcmopar's Avatar
Yup,
What Blue said!
Old Apr 6, 2005 | 01:11 AM
joefarmer's Avatar
Yep. MAP sensor -> FMS -> EZ -> Stock MAP wiring harness plug.
brnadon.
Old Apr 6, 2005 | 01:49 PM
600 Megawatts's Avatar
Muted User
Why would you do this? The FMS is both a timing and a fueling box. I understand stacking an EZ with a fueling only box, like a TST, but why would you do it with an FMS?? FMS 'wild' timing setting is a lot of timing. Is there more to this that I am missing??
Kevin
Old Apr 6, 2005 | 03:00 PM
Jetpilot's Avatar
FMS does not add timing.....
Old Apr 6, 2005 | 04:39 PM
HOHN's Avatar
Just for future reference of those who may find this by search:
The reason you always hook the "wire tap" box to the MAP first, it because
most derive fueling info from boost signal, which a timing box will screw up.
Fuel connected to MAP-- timing connects to fuel and CAN BUS.
Old Apr 6, 2005 | 04:59 PM
Beast2B's Avatar
AHHHHH, we finally get the 'why'!
thanks HOHN
Old Apr 6, 2005 | 07:39 PM
Muted User
[B] Jetpilot QUOTE: "FMS does not add timing....." [B]
Well on the Blue Chip Diesel web page it has link where it says "click here to test drive the FMS Box". It pulls up this neat screen where you can 'push' the buttons on the box with your mouse. In the FMS menu, there is a timing menu and there it says "Timing: OFF, MILD and WILD "
Furthermore I was told by a guy that the WILD setting will allow about 3° to 4° more advance than an EZ......
Kevin
Old Apr 6, 2005 | 08:07 PM
Scrambler250's Avatar
I've been told by Chip (of BlueChip) that the FMS box does not add timing. The mild/wild/none option is for people that stack boxes. You set the timing option based on what timing box you are running, and it alters the fuel delivery of the FMS.
Jetpilot's Avatar
Well I guess dynoing both stacked and unstacked will be in order then.....
Doug
Old Apr 6, 2005 | 10:35 PM
Muted User
Wow, I never would have guessed that !! I am glad this came up.. I was thinking about getting one, since it seemed to be timing and fuel and very adjustable.... So those settings in timing are for if you stack... wierd... Why doesnt chip just also add a timing feature to it??
Kevin
t-boe
Jan 4, 2007 08:35 AM
rubbert
13
Apr 22, 2004 02:19 PM
Gene007
Oct 27, 2003 03:43 PM
John_P
24
Jul 13, 2003 08:59 AM
