Help! Something seriously wrong
Old Jun 6, 2003 | 05:37 PM
Scotty's Avatar
Top's Younger Twin
Re:Help! Something seriously wrong
Jack, check the belt to see if its burned, if it is, then check to see if a bearing is out on your AC pulley or alternator or the others.
Perhaps a bearing failed or seized and the belt is ripping up.
Also, I think the belt tensioner on these trucks is plastic...it may have failed too.
Hows the voltage? Can you run it in Park and check carefully under the hood for tell tale signs of a bad pulley etc?
Old Jun 6, 2003 | 05:40 PM
j's Avatar
j
i too would say the belt. i had it happen on a jeep. the belt didnt break, it just jumped over a bit and was rubbing against the water pump. i'd start there though.
Old Jun 6, 2003 | 05:44 PM
Mexstan's Avatar
Agreed, start with the belt.
Old Jun 6, 2003 | 07:00 PM
Scotty's Avatar
Top's Younger Twin
[quote author=Jack Thorpe link=board=4;threadid=15586;start=0#146629 date=1054941092]<br>Put on the fuel pressure gauge. PSI at idle= 0-3. WOT= -5 <br><br>I guess we know what the problem was. <br>[/quote]<br><br>no fuel pressure gauge with power mods?<br>Jack Jack Jack, :<br><br>
Old Jun 6, 2003 | 07:11 PM
Dieseldude4x4's Avatar
WOW, hope you didn't smoke the injector pump.<br>Let us know what you find out on the booster pump.
Old Jun 6, 2003 | 08:40 PM
Haulin_in_Dixie's Avatar
Jack hope it works out well for you. If you look at my thread, I would have lost my injection pump if not for the pressure gage. At that I hope I did not drive far before I noticed it. They are a must on the Dodge.
Old Jun 6, 2003 | 09:08 PM
DPG's Avatar
DPG
Jack:<br><br>Sorry to hear about your lift pump. I replaced mine this spring with the Cummins stock pump and have had real good pressure readings. 15+ idle, 14 crusing at 60, 10 WOT. That's with Step 1 injectors and an EZ. The part number is 3990082 for the '99. Yours is a 99 like mine, right? Cost about $160.00 for the pump. <br><br>Good luck. <br><br>DeWain
Old Jun 6, 2003 | 09:35 PM
Don't make me send JohnP and Banshee down there to get you straight again. ;D<br><br>You coming up to Claremont in two weeks?
Old Jun 6, 2003 | 10:19 PM
MYTRNx3's Avatar
Sorry, need assistance... WOT - ?????????????????? Acronym for.......................
Old Jun 6, 2003 | 10:21 PM
MYTRNx3's Avatar
Ok thanks... someone needs to put them all on a page... like a dictionary
Old Jun 6, 2003 | 10:27 PM
Scotty's Avatar
Top's Younger Twin
[quote author=MYTRNx3 link=board=4;threadid=15586;start=0#146706 date=1054956110]<br>Ok thanks... someone needs to put them all on a page... like a dictionary<br>[/quote]<br><br>Its already done...<br>go here...<br><br>https://www.dieseltruckresource.com/...p;onlynewfaq=1
