HELP! No tail lights or dash lights.
Old 02-28-2009, 03:46 PM
cLAYH's Avatar
My dad now has my 2001 3500. He is in Moses Lake, Washington with it and his 5th wheel. His dash lights and taillights/marker lights have stopped working. He has checked the park lamp fuse and its shows 12V on both sides of the fuse. He has also replaced the dash head lamp switch. No improvement.
Is there a relay somewhere for this? Any other thoughts/suggestions? He is an instrument tech and has a few basic hand tools and a mulitmeter at his disposal.
Thanks.
Old 02-28-2009, 03:48 PM
cLAYH's Avatar
If anyone has a wiring diagram of the park lamp system they could send me I would appreciate.
Also he hasn't hooked up to the 5th wheel in over 3 months,its parked there while he is working. This just started a few days ago and wasn't caused by the trailer.
Old 02-28-2009, 04:47 PM
Busboy's Avatar
It could be a burnt wire at the headlamp sw. If there is ANY discoloration then that is the problem.
Old 02-28-2009, 07:46 PM
tlcavvy's Avatar
i had to put a blinker switch in mine when it did that exact same thing... was like $140... awesomeness.
Old 02-28-2009, 10:25 PM
cLAYH's Avatar
Blinker switch? You mean for the Hazzard lights? I wouldn't think the park lights would run thru that switch.....
Old 02-28-2009, 11:03 PM
AndrewK's Avatar
You should have two fuses for running lights, one in the truck and one under the hood. The one under the hood is effected by a trailer. 9 times out of 10 thats the one the has blown for me.
Old 03-01-2009, 03:14 PM
cLAYH's Avatar
Ok he found the fuse under the hood for the marker lights and it is blown. Putting in a new one just blew right away. There is no trailer hooked up. Any more thoughts?
Old 03-01-2009, 09:54 PM
GAmes's Avatar
Has he looked at the 7 pin receptacle for corrosion, or under the truck for a chaffing wire?
Old 03-02-2009, 12:36 AM
cLAYH's Avatar
He disconnected the the 7 wire plug at the back of the receptor, no change. Has yet to crawl under for a good look.
Old 03-02-2009, 12:37 AM
cLAYH's Avatar
I there an easy place to disconnect the wiring harness for the rear lights at the front of the truck to isolate where on the truck the problem maybe? What about at the back?
Old 03-02-2009, 01:25 AM
Lil Dog's Avatar
There should be a plug near the spare tire to branch out to the rear of the truck for lights and trailer. I would pull that off and see if it goes away, then pull out a DVM and check for shorts in the harness.
Old 03-02-2009, 07:14 PM
Bluedually4x4's Avatar
Stupid question, but does the truck have the factory radio in it, or is it aftermarket. I had that same problem and it was caused by the radio's wiring harness. The wire that tells the radio to dim when you turn the lights on was shorted out and that kept blowing the fuse.
I hate the wiring in these stupid trucks.
Old 03-02-2009, 09:01 PM
GAmes's Avatar
Did he try disconnecting the brake controller?
Old 03-03-2009, 06:16 PM
cLAYH's Avatar
Yes it does have an aftermarket radio but its a good quality Kenwood and its been in a LONG time. Just in case though were you blowing the underhood fuse or the dash fuse?
Old 03-03-2009, 06:17 PM
cLAYH's Avatar
Nope. How does the brake controller affect the parking lights? Brake lights I could see but there are only 4 wires on the brake controller, power, ground, brake line tap and then out to the trailer plug. Am I missing something?
Quick Reply: HELP! No tail lights or dash lights.
