HELP!! My 4 HI will Not Engage but $ Low will engage!!??
At the same time the 4x4 light does not go on anymore while I put it in 4 hi, which dfoes not engage but 4 Low works!!!! But still no 4x4 instrument light on either setting, has anyone had this before or think of what this could be, I am not a mecanic but the linkage seems like it is working and I only have 65,000 miles on it! Of course this happened right after I took it in for the lift pump replacement! Thanks!!!! its a 2001
Do you have manual hubs or are they electric? when I got my 98 the indcator light wasn't working I thouhght that 4x4 wasn't working aslo. Put it in low and new transfer was shifting went to high took it on a tight turn radius to find out if front end was engaging. Bucked like a yearling. found that wiring harness on front end was unplugged. Might be your problem.
When I put it into 4 hi it will not Buck at all no matter how tight I turn on dry road, but 4 Low bucks hard. I will check out the linkage and vaccuum lines today, also the 4X4 light does not come on at all in either 4x4 mode. Thanks for the help guys!!!!
J_T
16
01-15-2019 09:59 AM
BigDodgeBigHart
04-13-2007 10:26 AM
