Help Injectors
Old 04-13-2007, 03:27 PM
YZ3500F's Avatar
Help Injectors
How do u get air out of your injectors lines and purge the whole fuleing system
Old 04-13-2007, 03:51 PM
RowJ's Avatar
Need signature filled in with truck description...yr,model, etc.
Normally you loosen injector fuel line to #3 & #4 injectors and bump starter to activate fuel pump (runs about 30 sec) till fuel comes out. Retighten and start.
RJ
Old 04-13-2007, 08:31 PM
YZ3500F's Avatar
2002 3/4 Ton with the HO motor
do you loosen the injectors or do u loosen the line coming out of the VP44
Old 04-13-2007, 10:12 PM
J Lent's Avatar
Just loosen the line going into the head....3/4 inch wrench. Then bump the starter on/off...you will hear the fuel pump run & tighten the lines when you see fuel coming out & no air....make sure your fuel pump is running while you tighten them.
Old 04-15-2007, 07:45 AM
Clunk's Avatar
19mm wrench fits too.
KRB
05-20-2007 06:20 PM
GSP
12-11-2005 12:20 PM
W.F.O.
11-03-2005 10:33 AM
darrenG
06-21-2005 10:24 PM
BIGOKIE
07-21-2004 05:53 PM
Quick Reply: Help Injectors
