help identify 6 speed
Old 05-21-2010, 12:00 PM
asa
asa's Avatar
hello I purchased a 6 speed manual trans from a late 2003 dodge for a cummins conversion. This trans has a cast steel case not aluminum like the one in our 2004 dodge. Need help with identifying what I have . thanks
Old 05-21-2010, 01:20 PM
no_6_oh_no's Avatar
That will be an NV5600. Your 2004 had the same trans from the factory, if it has an aluminum case with the bell housing integrated then it is probably the newer G56 and it was put in after the fact. The G56 did not go into production until mid 05.
Old 05-21-2010, 01:31 PM
carbuff415's Avatar
Also different between the NV 5600 and the G56 is the location of Reverse. If is it up next to 5th, it is a 5600. If it is down by 2nd, it is a G56.
Old 05-21-2010, 02:15 PM
asa
asa's Avatar
thanks guys thats what I needed to know
raven5
09-18-2006 11:15 AM
nobody
08-21-2006 05:20 PM
gsracer
07-23-2006 04:10 PM
barn6720
03-30-2006 12:04 AM
stillsmokin
01-08-2006 09:18 PM
Quick Reply: help identify 6 speed
