Help with finding part
Old 11-21-2010, 04:08 PM
max924's Avatar
Hi, I have been rebuilding the frontend on my '91.5 W250. My spindle bearing and seals were toast on one side so I bought the kit (bearing and two seals) but it does not include the bushing/thrust washer which is also worn very badly. I can't seem to get anywhere with the local parts stores, does anyone know any part #'s for this bushing?
Max
Old 11-21-2010, 08:31 PM
raggmann's Avatar
IF I remember right the BCA number is SBK3.
I got mine at my local jobber.It came with the torrington spindle bearing,thrust plate,and seals.Check with your local parts store and see if they've got one to look at.
After being on a parts counter myself for 20 years it's possible that yours were missing parts from the factory OR someone only needed the thrust washers so bought the kit, took out what they wanted, and returned the kit......it happens and makes the parts store look bad.
Old 11-22-2010, 05:45 AM
dzl_damon's Avatar
I believe that happened to my cousin with his Chevy Dana 60. One kit had it, and the other didn't (might have been 2 seperate companies). Look at other kits.
Old 11-22-2010, 08:30 AM
ghenges's Avatar
Originally Posted by max924
Hi, I have been rebuilding the frontend on my '91.5 W250. My spindle bearing and seals were toast on one side so I bought the kit (bearing and two seals) but it does not include the bushing/thrust washer which is also worn very badly. I can't seem to get anywhere with the local parts stores], does anyone know any part #'s for this bushing? Max
http://www2.dana.com/pdf/X510-5DSD.pdf
If your local parts suppliers can't order it in, you can Google 707469X to find a supplier online, I believe this part number is what you're looking for.
Happy Thanksgiving.
Old 11-23-2010, 08:02 AM
max924's Avatar
Thanks for the help, turns out that NAPA only sells the BK3 kit which does not include the bushing, CarQuest sells the SBK3 kit which includes the bushing.
Max
Old 11-23-2010, 08:37 AM
raggmann's Avatar
Glad you found what you needed.
TrkEnvy
06-30-2013 07:29 PM
12valvin
01-08-2012 07:55 AM
seahawkdodge
05-12-2009 11:30 PM
pwrtripls1
02-15-2009 11:12 AM
VjjR
02-12-2008 07:10 PM
Quick Reply: Help with finding part
