Help Fast Please!!!!!!!
Hey guys i have big problem...so when i drive my truck and hit brake pedal it starts to chugg real bad then starts to climb in rpm while holding brake then thru it in neutral and revs to like 2200 to 2500 rpm then pops back down...took smarty off because thought nit was that but it is still doing it??????? please help.......
ya me and my buddy pretty sure it the Torque Converter it is locking up at idle which makes the motor chug then computer sees that rpm is low so it fuels which the harder u push brake more it fuels then when u let off it launches hard and the tc stays locked..... hey one quick question? When should the TC lock up? Is it in 2,3 and 4th... mine only locks up in fourth and it pulls hard..
The TC locks up in 4th unless you are using OD lockout, then it will lock in 3rd. I think I remember reading they can lock up in 2nd with 2nd selected with the shifter, can't remember. You may have to mod the VB to do that. Just not sure.
pretty sure you disconnect both battery neg cables for half an hour, then reconnect, turn key to run, slowly press fuel pedle to floor, slowly let up, shut truck to off, then start truck. if there were codes involved in the truck leading you to try to reset, remember it takes several starts of the motor without issues to stop the code from coming up.
EdmontonCanada
37
12-09-2009 03:18 AM
Emoneysrt-6
10-21-2008 11:17 AM
