4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Help with error code
Old May 9, 2011 | 08:28 AM
ranchertx's Avatar
I got in my truck this morning and there was an error code on the dash which said "Did not train".
It did not go out, and the other functions on the computer were not available.
Anyone else have this? I wonder if Smarty Jr will clear it?
Old May 9, 2011 | 08:53 AM
cbrahs's Avatar
Fill out your signature so we know what you are driving. smarty can only clear engine codes. more than likely it is a body code but get your sig filled out so I can research it.
Old May 9, 2011 | 09:01 AM
ranchertx's Avatar
Sorry, 2010 2500 Cummins.
Old May 9, 2011 | 09:14 AM
dawghlr's Avatar
Do you have the garage door openers built in to the over head?
If so that is the mesage someone pushed one of the train buttons but it did not sense the signal from the other door opener and is telling you it didn't get it. Push both outside buttons at the same time untill the dash says memory errased and you will have to reprpgram your door opener, if that is not it then I have no idea.
Old May 9, 2011 | 09:15 AM
dawghlr's Avatar
same message happen to me one time.
Old May 9, 2011 | 09:22 AM
ranchertx's Avatar
Ok, thanks. will try that. Yes I do use that overhead opener to open my gate. it has been working fine.
Guess it got a case of the mondays.
Old May 9, 2011 | 09:37 AM
cbrahs's Avatar
i am not seeing anything in Chyrlser. will continue to look though
Old May 10, 2011 | 10:42 AM
ranchertx's Avatar
Just a follow up.
I got in the truck yestrday afternoon and the message came up as soon as I turned on the key. I pressed the first button of my garage door opener and it cleared the message out.
Not sure why the system decided that is was supposed to be learning a new code.
Thanks for the help guys.
DMS1707
Sep 1, 2017 11:41 AM
edhunter
Jul 29, 2014 12:37 PM
ziggy
Jun 24, 2013 05:57 PM
justagoodolboy
Jun 10, 2009 08:51 AM
benterry
Feb 20, 2006 09:56 AM
