Help...Electrical problem
Old 07-06-2007, 12:40 AM
klsmailes's Avatar
Exclamation Help...Electrical problem
I removed all the fusable links and replaced them with a fuse block. I now have no radio, no interior lights, and no power mirrors. I checked fuse #15 a 10 amp and it was fine. However, after checking for current there I found none. Is there perhaps a breaker hidden somewhere that might have failed or am I going to have to trace this thing through the wiring harness? Please any suggestion would be greatly apprieciated. Thanks, Kevin Smailes
1992 w350 regular cab
Old 07-06-2007, 12:47 AM
TexasHardcore's Avatar
...But why?
Old 07-06-2007, 02:08 AM
MikeThomas's Avatar
Hmmm, should be straight forward. Make sure you removed the full link of FL's. Just double check all of the connections, and check the fuses under the dash...lost a FS and it took out a corresponding fuse...I would replace the FL's with some fuses any day, just havent had the time yet.
Old 07-06-2007, 05:55 PM
You missed something when you replaced all the links. Go back over your work and check it thoroughly.
MRFD715
08-03-2008 05:02 PM
joshua smith
01-12-2008 09:35 PM
Cummins Freak
07-31-2006 07:09 PM
blackjack
05-09-2004 05:38 PM
canucktrucks
03-04-2004 06:52 PM
Quick Reply: Help...Electrical problem
