HELP... DTT T/C triggered code P1740
Old May 13, 2006 | 12:42 PM
DirtEater's Avatar
Has anyone else had P1740 and know how to get rid of it? I recently had a DTT tranny upgrade, and drove the truck from the DTT installer shop located in the Phoenix area back to my home in San Diego. About one mile from my house, the CEL came on.
The code reads P1740(Torque Converter Clutch Inductive Signature Malfunction). I tried to clear it 3 times using the scanner at Autozone, but it stayed on. Also tried disconnecting both batteries for about 2 minutes and it still has the CEL.
The tranny works just great but I'm not diggin the CEL at all, especially if I need to take it to the dealer for unrelated warranty work.
Old May 13, 2006 | 04:07 PM
tweeter's Avatar
I'd be taking the truck back to where the transmission was installed, if the fault is hot (won't clear) it may be as simple as a sensor being unplugged (ie an internal speed sensor). The torque converter is just spinnin in there, it doesn't have any electrical outputs that would set a code, or any tone rings that need to be read, good luck.
Old May 13, 2006 | 04:31 PM
DirtEater's Avatar
I do agree with you, but SD to Phoenix trips aren't too easy finding the time to do so. For $3400, there shouldn't be a CEL though.
Old May 14, 2006 | 09:08 AM
TAS05CTD610's Avatar
It could be a lot of things, and as I've found out, sometimes it's truck specifit, like you have a bad transmission ground, that would be DC's issue not the trans guy, just because maybe it moved a little bit, and it changed. There's so much that can go wrong.
I work in biotech, there is no 99% it's 100% all the time or every batch we screw up (every 2 days) is 40million down the drain. So yeah, adds up to a ton of money. It's almost impossible to do it perfect. I mean I'm the same way, if I take something some where it should work, like yours does, yes there is a code being thrown but that's rare. Look at the thread about the dealer who forgot to put the oil plug in???? Common, now that is just stuipd
Call them up, they may be able to tell you what's wrong. When did the code show up? On the way home? It's odd that if it wasn't on when you left, but when you were driving??
Old May 14, 2006 | 01:04 PM
DirtEater's Avatar
I was driving from Phoenix(where the work was done) to my home in San Diego, the day after the tranny work. The code didn't show up until until I was a mile away from my house. It's about a 350 mile trip or so. Kinda weird.
Old May 14, 2006 | 04:33 PM
That's odd, like I said kinda like when you fire a motor up, if somethings gonna go, it's gonna go in the first few minutes, the fact that it didn't show up till then, is odd. Maybe it's something that has to be driven. I know some of the codes you cycle start the truck a few times and they go away.
In fact I had a 336 (Cam due to TST) and the engine light went away. And come to think of it, I have a brand new scanner I"ve never used. hmmmmm, I'm going to have to play when I get home tonight
I do believe the check engine light will go off, but the code is still there. NOt 100% on that though.
mhuppertz
Jul 23, 2008 10:28 AM
CTD600
Jul 19, 2007 12:03 PM
LFD2037
Sep 13, 2006 05:06 PM
rockjeep73
Feb 9, 2006 07:12 PM
Turbo Deeezle
Jun 4, 2005 10:18 PM
