HELP with CPS Problem!!
Old Dec 12, 2006 | 07:28 PM
98.5POS's Avatar
Exclamation HELP with CPS Problem!!
As of today my truck has began to run very raggety when you first start it, warm or cold, the tach bounces with the motor for about 30 seconds and then clears up. When it clears up the tach looses single and 0's out. The tach in my Atitude moniter still works though.
I changed the cam position sensor under the IP first no change, then pulled the starter and changed the crank position sensor. When I pulled the crank sensor out it looked like something had hit it. I put a new sensor in and still get the same engine code and problem. Is there a spacer that goes on them? It looks like it's hitting the tone ring on the crank. Has anyone seen this before?
Old Dec 12, 2006 | 08:30 PM
98.5POS's Avatar
Anyone there??
Old Dec 12, 2006 | 09:02 PM
01PPUMP's Avatar
Pull your new crank sensor back out to see if it has been hit also. I is rare but yes I have herd of this, the tone wheel is working loose on the crank.
Old Dec 12, 2006 | 09:42 PM
98.5POS's Avatar
What is the fix for this? I hope not pulling the engine, or maybe I could pull the pan in the truck. Is that possible?
Old Dec 12, 2006 | 09:48 PM
01PPUMP's Avatar
Yes, it is possible to fix it by just pulling the pan.
Old Dec 12, 2006 | 09:56 PM
98.5POS's Avatar
Can the ring be tightened in the block?
dodgecrawler
May 14, 2013 10:07 AM
papajoeky
Mar 6, 2013 06:28 PM
mustangracer
Nov 12, 2006 11:57 AM
John In NC
Oct 22, 2005 09:14 AM
BigBlackDodge
Mar 16, 2003 09:04 AM
