HELP, Codes need help fast!
Old 01-11-2008, 03:07 PM
Sam Turner2's Avatar
06 CTD acts liek its running on 5 cylinders.
Codes P2149
0514
0513
0205
no mods stock truck. I havs looked them up already, can anyone diuagnose my problem?
Old 01-11-2008, 03:14 PM
53 willys's Avatar
P2149-BANK 2 (CYLINDERS 4-6) SHORTED HIGH OR LOW
WHEN MONITORED
While the engine is running.
SET CONDITION
A misfire detected at cylinders 4,5, or 6 or any combination of cylinders 4,5, or 6.
POSSIBLE CAUSES
  • Other DTC's
  • High side driver circuit open
  • Low side driver circuit open
  • High side driver shorted to low side driver
  • High side drivers shorted low
  • Low side driver circuit shorted other low side driver circuit
  • Low side drivers shorted low
  • High side driver shorted to voltage
  • Low side driver shorted to voltage
  • Low side driver circuit shorted in injector harness
  • Injector
  • Injector harness
  • ECM
  • Intermittent condition
P0514-BAT TEMPERATURE SENSOR RATIONALITY
WHEN MONITORED
SET CONDITION
The ECM does not read a change in value from the sensor over time.
POSSIBLE CAUSES
  • Battery TEMP sensor
P0513-SKIM INVALID KEY ERROR
WHEN MONITORED
Key on
SET CONDITION
Invalid Key Code received from SKIM Module
POSSIBLE CAUSES
  • General network error
  • Key not programmed
  • Incorrect key
  • Incorrect VIN IN ECM or SKIM
  • Loss of communication between ECM and SKIM
P0205-INJECTOR #5 CONTROL CIRCUIT
WHEN MONITORED
SET CONDITION
When the injector current falls below a calibrated threshold.
POSSIBLE CAUSES
  • Pass trough connectors open
  • Fuel Injector
  • Injector harness open
  • High side driver harness open
  • Low side driver harness open ECM
any other info about the truck???
installed anything new lately???
Old 01-11-2008, 03:16 PM
sootindiesel's Avatar
P0514 BAT Temperature Sensor Rationality
P0205 Injector #5 Control Circuit
P2149 Bank 2 (Cylinders 4-6) Shorted High Or Low
not sure what the 0513
Old 01-11-2008, 03:20 PM
No, nothing new, 120K miles, Has done a smiliar thing before and we pulled over, drained the water trap, wiggled every connecxtion we saw and it carnked up and it ran good, not this time.
Old 01-11-2008, 03:22 PM
no chip, not straight pipe,nothing, bone stock... Second owner, truck smokes like crazy when you hammer down on it, 6SPD, so it may have a set of injectors in it??? (good ole black smoke)
Old 01-11-2008, 03:24 PM
53 willys's Avatar
I would try looking for a chafed connection some where....ECM plug?? injector plug?? something sounds loose or chaffed to me or a bad connection of some sort??
Old 01-11-2008, 03:25 PM
Ok Thanks, will check out and report
Old 01-11-2008, 03:28 PM
53 willys's Avatar
you are probably going to have to take it in so someone with a scanner can check it better....hows the oil level??
Old 01-11-2008, 03:29 PM
53 willys's Avatar
do you have a volt meter that can do Ohms???
Old 01-11-2008, 03:32 PM
dodgezilla04's Avatar
i have seen where the injector connectors(under the cover) have contacted the rockers, causing the short... just required a loosening of the retaining nuts for the wire lugs and position them so they cant touch anything metal.
Jim Lane
12-07-2015 09:16 PM
exwrestler
02-05-2010 09:34 AM
EdmontonCanada
37
12-09-2009 03:18 AM
mbenedict
07-21-2007 09:19 PM
trik396
03-14-2007 07:57 AM
Quick Reply: HELP, Codes need help fast!
