Help.. Check eng light on
Old 02-25-2010, 03:15 PM
2Armor's Avatar
Drove to work no engine light on, depart work after 9 hrs.. Lights on solid.
I checked for codes and it listed nothing. All gauges normal when running, etc. Where should I start with no code?? Disconnect battery for 10 minutes??
BTW the truck just turned 54,000 miles.
Thanks in advance for the help
Old 02-25-2010, 03:31 PM
hector's Avatar
engine lite & no codes ?? Did you check with code reader in the obd11 port ??
Old 02-26-2010, 09:39 AM
2Armor's Avatar
Not sure what the obd11 port is/entails I'll presume its a hand held reader- if so no. I just did the self check/ gauge diagnostic with the odometer button and turned the key on. It said "code 00 00" in the mileage display. Maybe I need to use that odb11 port to check it properly(?).
UPDATE- Now this morning I started it up and and the check engine light turned off at startup (like normal) . I guess thats good but what would cause it to stay on for two days (25 miles/ 35 minutes of run time), then turn off by its self?
THANKS!
Old 02-26-2010, 01:53 PM
RamWheelsBy4's Avatar
The CEL light will come on when a code or problem is detected. If the problem is not present, the CEL will turn off on its own after 4 full start run cycles. Now a DTC code should still show.
The sequence you used with the key is to check and display Instrument Cluster codes.
To view DTC codes just turn key on/off, on/off, on and leave on and it will display any DTCs stored.
Old 02-26-2010, 02:48 PM
Administrator/Jarhead
madhat's Avatar
You checked C codes... check out this thread...
https://www.dieseltruckresource.com/...s-t224833.html
Old 03-01-2010, 07:57 AM
2Armor's Avatar
Ah crap, I did it that way a while ago when I read the thread but forgot about that sequence. I did it a year ago to see if it worked and saw no codes. THANKS for pointing me in the right dirrection!
Now I'm seeing code P 0514. Guess I'll search for what that means and what to do!
THANKS AGAIN.
Old 03-01-2010, 08:05 AM
2Armor's Avatar
I found that p0514 code is called "battery temp rationality" I also see many say something along the line of- "I get the p0514 every winter. Mainly due to having subzero temps and plugging the truck in with a battery pad. I ignore it as most do, up here anyways."
It is winter here and my batteries are goin on 7 years old. I guess I'll be going looking at getting two new batteries.
Any recommendations / do's or don'ts? I have always had good luck with SEARS DIE HARD batteries. Thanks Shan-
Old 03-01-2010, 08:09 AM
Lost Lake's Avatar
THANKS AGAIN.
P0514 Battery Temperature Sensor Performance / Rationality
Is it under warranty? I've heard the sensor could have failed... Should be a minor repair. Good luck!
Old 03-01-2010, 08:12 AM
Lost Lake's Avatar
Oooops, you beat me to the post!!
I've always found Interstates work hard and long for me, but Die Hard are VERY highly rated in the last Consumer Reports I read about batteries.
I suppose every battery is different, and maybe car batteries are built differently than truck batteries.... 7 years is a good run for your batteries....
Old 03-01-2010, 09:48 AM
2Armor's Avatar
I was impressed with 7 years on the OEM battery but they still seem to be good too. Cranks over easy and fast and its been in the 20s-30 here too. I also see posts where some are getting as much as 9yrs on their batteries.
Now should I blow the $$$ on new batteries based on a code or clear it and wait? I dont have a battery load tester.. I dont know how to clear the code either. back to my search friend.
Old 03-01-2010, 09:51 AM
2Armor's Avatar
[QUOTE=Lost Lake;2713909]P0514 Battery Temperature Sensor Performance / Rationality
Is it under warranty? I've heard the sensor could have failed... Should be a minor repair. Good luck![/QUOTE
It'll be seven years old in July and I have to take it in for some TC issues ( make noise when 4wd is engaged..chain maybe). I dont know if this is covered in that drivetrain warranty. As soon as the weather warms u a little, I'll drop it off so I can commute on my bike. Dealer dont have loaners go figure.
Old 03-01-2010, 10:42 AM
madhat's Avatar
That sensor should be easy to test... just a multimeter and a hair dryer... hang on, let me look...
Old 03-01-2010, 11:03 AM
madhat's Avatar
Nope, it says you have to use the OBDII... sorry.
I'd ask if you remove it and bring it in, would they cut you a break.
Old 03-01-2010, 11:30 AM
2Armor's Avatar
I was actually talking about taking the truck in for Transfer Case warranty repair, not battery issues- unless it is covered under that 7yr/70k warranty(?).
I'm not sure where that sensor even is..
Old 03-01-2010, 11:31 AM
madhat's Avatar
I don't think that is. I could be wrong. Only one way to find out!
Quick Reply: Help.. Check eng light on
