HELP! where is the block heater cord stowed?
Old 12-20-2004, 06:50 PM
Hummin Cummins's Avatar
Hey guys. first time I decided to need to run the rig in such cold weather.
I've searched for the cord in single digit temps until I couldnt feel my fingers anymore and decided to give yas a try in where I should look first.
Thanks.
Old 12-20-2004, 06:54 PM
kingofdodge7131's Avatar
Im 99% sure that the 3rd gens just have the heater installed but no cored. Something in the range from 25-30 US smakerroos from a dodge dealer. I havent bought one. Just what i hear
Old 12-20-2004, 06:55 PM
aceheater's Avatar
passenger side front corner should be just long enough to hang out on the bumper .. I don't know what year DC started doing this but they made the block heater an option just another way to save money llike the rear inner fender wells ...
Old 12-20-2004, 07:16 PM
phox_mulder's Avatar
If you do indeed have the cord, check in and around the passenger side headlight.
Pretty sure the 03's came with the cord, DC didn't make it an option till the '04's.
All Cummins in Dodges come with the block heater, just the latest 3rd gen's don't come with the cord unless you specifically order it.
If you did get one without the cord, stay away from Dodge, get it from Cummins, much much cheaper.
phox
Old 12-20-2004, 07:27 PM
jrs_dodge_diesel's Avatar
Or on the block kinda behind the oil filter (in that area somewhere), is where your heater is. If it has a cord follow it back. If not go get one from a cummins distributor. They are much cheaper there.
Old 12-20-2004, 07:59 PM
nitrousn's Avatar
2 of my friends bought 03's and neither one had the cord.
Old 12-20-2004, 08:15 PM
dodgedude361's Avatar
i have the chord, look by the radiator, bottom left side
Old 12-20-2004, 08:17 PM
handymantim's Avatar
Open the hood before you start looking near the passenger headlight. The cord is tucked away when it arrives from the factory and having the hood open will help. When you find it and release it, it will just barely make it halfway to the front of the bumper.
Old 12-20-2004, 08:51 PM
Ramtough's Avatar
paid $11 and change at my local cummins dealer. A nuisance to install. I had to take the intake tube off and grease the rubber with some die electric grease to get er in.. ran it down to the frame rail and up to the altenator bracket. had some extra cord so i ran it over to the pass. foglight hole. Too Bad there is no outlet on the outside of my apt. building....
wonder if i asked nice if they would put one in.
Old 12-20-2004, 09:45 PM
Thanks guys
I know I saw it under there the one day.
Some jostled a neuro synapse and I think it is behind my passenger side headlight (IIRC).
Mine has the block heater and cord. I know that.
(or am I thinking of my former Chubby diesel???)
Old 12-20-2004, 10:15 PM
clifford's Avatar
I had to look and it is there by the righthand head lite.
Old 12-21-2004, 01:41 AM
nickleinonen's Avatar
all canadian models get the cord as standard equipment [it was not an avalable option for my 04 when i ordered it... and looks like it isn't an option on the 05's either]
Old 12-21-2004, 06:06 AM
FROSTY1's Avatar
Go to the Tech Facts section of this site. Then click on the 24v 3rd generation category, and there's a whole description of the block heater there for you that should answer all your questions. https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old 12-21-2004, 07:14 AM
Blue600's Avatar
Cord was $11.46 at the local Cummins shop.
Old 12-21-2004, 07:56 AM
Thats MR Hoss to you buddy!
Hoss's Avatar
Maybe it's just me, but I have to open my hood EVERY time I plug in or unplug. Opening the hood is the ONLY way to find it.
Quick Reply: HELP! where is the block heater cord stowed?
