Help with battery drainage
Old 05-30-2010, 09:12 PM
extremeshot's Avatar
Unhappy Help with battery drainage
Can anyone help me figure out why my batteries go down 2 to 4 volts in about 5 to 7 days. My truck is stock no mods except for a compressor for my air bags. It an 2006. Im not that good with electrical problems they suck. Any help Thanks
Old 05-30-2010, 09:22 PM
Tacomaman87's Avatar
kind of hard to diagnose a draw on the over the internet i would try pul;ing the fuse for the airbags and see if that helps at all
Old 05-30-2010, 11:09 PM
RDM16CTD's Avatar
Maybe the batteries are the problem - check and make sure the terminals are clean and have a good connection. If that checks out ok then get the batteries and charging system checked out to make sure all is good - most auto parts stores (Checker Auto, Auto Zone, etc) will test them for you for free.
A next step would be to hook up an amp meter and confirm that there really is something drawing current when everything is supposed to be off. It's not a hard test but if you're not comfortable doing the electrical work maybe find a friend with more experience in this area. Once the amp meter is installed you can remove fuses and circuit breakers, each in turn, and find which circuit is causing the problem (the current draw will stop when you pull the fuse on the problem circuit). But I wouldn't disturb everything before checking out the basics first - battery terminals, condition, and charging circuits. Let us know what you find out
Old 05-31-2010, 10:01 AM
Thanks RDM16CTD, I will do that. Thanks again for your input, Just one more question, where do you install the amp meter? Thanks
Old 05-31-2010, 11:44 AM
jkitterman's Avatar
You are better taking your truck to someone. Test meters are not cheap and I would hate to see you fry your ecm or something else expensive just trying to save a buck. Take your batteries out, have them charged and load tested. If it is more than that, take it in.
Chrisreyn
05-14-2013 09:15 PM
77machomopar
08-14-2009 06:15 PM
redpoint5
05-16-2007 07:52 AM
planejane
08-23-2004 03:17 PM
doodah
02-12-2003 07:57 PM
Quick Reply: Help with battery drainage
