HELP Autometer Oil pressure gauge noise please help!!!!
Old 10-11-2006, 08:37 PM
QWKRTNU's Avatar
I got a mech oil gauge and it makes this hum noise when i let off the gas or apply slight pressure to the throttle. Anyone else have this issue??? Or is it a bad gauge. Thanks
Old 10-12-2006, 01:03 AM
QWKRTNU's Avatar
no one know anything
Old 10-15-2006, 02:35 PM
QWKRTNU's Avatar
one last try. Anyone have noises with any gauges
Old 10-15-2006, 02:52 PM
trik396's Avatar
I don't have mechanical guages but I'd guess your getting the vibration directly from the engine thru the oil hose...?
Maybe there's some sort of "snubber" or isolation piece you can add to the hose to reduce the hum. Good luck.
Old 10-15-2006, 02:54 PM
trik396's Avatar
I had mechanical Autometer guages in my old hot rod.... But I couldn't hear anything because it was a mechanical lifter, 509cubic inch rat with dual 3.5" exhausts dumped right before the rearend... Talk about rumble...
Old 10-15-2006, 02:56 PM
QWKRTNU's Avatar
I know it is the oil becasue I disconnected it and it was gone so it sucks. Is sounds like I have a hum like the guys with the dicol boost gauges. Maybe putting rubber hose along the whole oil line. But the trans and fuel work great.
Old 10-15-2006, 02:59 PM
cmnspwr's Avatar
Have you got a 1/8" nylon hose, or braided stainless running to the gauge?
Old 10-15-2006, 03:01 PM
QWKRTNU's Avatar
I got brass line. Have had nothing but problems with the clear crap that comes with it.
Old 10-15-2006, 03:02 PM
trik396's Avatar
My guess is your brass line is absorbing alot of harmonics from the Cummins and transfering them to your guage... Just a guess.
Old 10-15-2006, 03:04 PM
QWKRTNU's Avatar
Im not sure. I have always ran copper tubbing to all boost and oil gauges before. But this is the first diesel i have done this too
Old 10-24-2006, 12:12 AM
QWKRTNU's Avatar
I ran fuel line over the brass line from the engine to the gauge and it is gone. So if you run brass cover it in fuel line no more noise. Thanks for all the help.
Old 10-24-2006, 08:23 AM
trik396's Avatar
ado2b1
07-06-2007 10:27 PM
rjm022
15
02-03-2006 09:35 AM
ASTAR
18
02-03-2006 09:27 AM
Buckshotmckee
01-27-2005 09:48 AM
pmtg
01-17-2004 01:08 AM
Quick Reply: HELP Autometer Oil pressure gauge noise please help!!!!
