HELP! APPS voltage problems
Old 08-12-2010, 05:08 PM
Ada381's Avatar
So I put in a new APPS from Timbo due to having a couple codes that suggested the problem was with the APPS (low voltage/high voltace and a general fault code). Installed the new APPS and checked the voltage as informed and was only at .475 and wouldn't go past .488 with wide open throttle. Any ideas of what may be causing this low voltage? No new parts and has ran great the last year. Thanks!
Old 08-12-2010, 05:20 PM
dkenny's Avatar
check the 5 volt line feeding the apps..sounds like gone..
-dkenny
Old 08-12-2010, 05:31 PM
Ada381's Avatar
Where would the 5 volt line be located?
Old 08-12-2010, 08:28 PM
Ada381's Avatar
Timbo has been a great help. Going to check the vlotage from the ECU in the am. Lets hope it is a simple fix but my luck it wont be. Anyone have an idea it will cost for a new ECU if that is the problem?? Thanks as well to you dkenny!
Old 08-13-2010, 06:50 AM
dkenny's Avatar
you should be able to find the 5 volts on the connector at the apps.
if it were me and 5volts from the ecm gone I wire in a $5 circuit using and LM7805 voltage regulator.
-dkenny
imbodie
21
01-08-2024 08:49 AM
smokinram99
02-04-2010 12:33 PM
hamilton71801
12-02-2007 07:32 PM
wadecool
03-25-2007 02:01 PM
DuaneWKKC
10-26-2006 06:59 AM
Quick Reply: HELP! APPS voltage problems
