PDA
View Full Version : help on the '82 w350
thebabybrahma
06-17-2009, 09:03 PM
Got the brakes fixed and starting good so we can hunt some parts. i am going to put dual wheels on it, need some help.
#1 can i use a 1" spacer in the rear with longer wheel studs on my dana 70?
#2 what kind of spacer/setup do i need for the front dana 60?
i have a set of dual wheels 16x6, that are ready for some tires, just as soon as i get some sort of setup to conver ther over to duals.. thanks for the info....[duhhh]
CE_TX
06-17-2009, 09:18 PM
On the front just swap your SRW hubs (bearing) to DRW hubs. All the parts are the same except the rotors and wheel studs. That is if you have internal style hubs on your front Dana 60.
You will have to find a DRW dana 70 or 80 for the rear. I'm almost positive spacers won't allow you to run dual wheels correctly or safely.
RumbleFish
06-18-2009, 10:48 AM
sure you can run spacers, but make sure you get good, quality ones. i would contact arrowcraft and see what they say. dont get some cheap ones off the 'bay, this is an area you dont want to skimp.
and post pics when youre done!
