Hello, what is the best way to clean my Amsoil air filter?
Old 11-11-2009, 01:21 PM
jmccart's Avatar
Hello. Like it says. If I recall, no water?
Old 11-11-2009, 02:00 PM
tryNto's Avatar
No idea, what did the directions say?
try google.
try AmsOil web site...
Old 11-11-2009, 02:17 PM
RowJ's Avatar
If you using the Microfiber EaAU dry filter....
-light compressed air from the inside. 20 psi
-brush, or vacuum off the outside.
-reinstall
RJ
Old 11-11-2009, 02:31 PM
knc77's Avatar
I recall they even suggested you could use a vacuum to clean it in the instructions.
I use compressed air. They are a pretty tough filter so I tap mine to loosen the trapped particles.
Old 11-11-2009, 03:36 PM
JJPage's Avatar
The following is off Amsoil's website.
Cleaning
EaA filters should be cleaned every year or 25,000 miles, whichever comes first. Carefully remove the filter from the housing. Clean the housing with a shop towel, being careful not to knock contaminants into the air inlet. Filters can be cleaned by carefully vacuuming the filter media on the dirty side, or by holding the filter with one hand and carefully blowing the filter media at a 45 degree angle on the clean side using low-pressure shop air (15-20 lbs. psi)
Old 11-11-2009, 05:25 PM
jmccart's Avatar
Great info guys, that is all I need.
Thanx.
Old 11-12-2009, 01:27 PM
AlCorr's Avatar
Looks like it's time I cleaned mine, thanks for the info.
skindaddy
02-28-2009 12:36 PM
cjones42
08-19-2008 06:54 PM
jmccart
02-18-2008 10:19 PM
czkid
10-18-2007 07:38 PM
sakisaki400
05-01-2007 09:55 PM
Quick Reply: Hello, what is the best way to clean my Amsoil air filter?
